Question about Husqvarna Viking 1
Viking # 1 only sews straight stitch but won't zig-zag
Is there another possible solution besides a new motherboard?
  • Husqvarna Master
  • 7,365 Answers
It could also be a worn part, only a sewing machine repair shop can say for sure
Posted on Feb 25, 2012
3 Suggested Answers
  • 201 Answers
SOURCE: Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
Posted on Jul 01, 2008
  • 1456 Answers
SOURCE: I have a Viking 6370 sewing machine. I can not
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Posted on Jul 12, 2011
Testimonial: "That was the problem exactly. I am going to order a new cam gear and replace it. Thanks"
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
154 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
