Question about Philips PPF-531 Plain Paper Thermal transfer Fax
Replacing Inkfilm I have followed the instructions as clearly as possible for replacing the inkfilm on ppf531r yet everytime I close the the lid, I keep getting the message 'REFILL INKFILM'. Hope you can help. Thanks
  • 21 Answers
Try this little trick that I have discovered. Press START for 4 seconds, then you will hear 2 beeping sound. Then alternately press START and STOP 4 times. You will see a cursor like display on the right side of the LCD. Press MENU or FUNCTION then input 97. Look for "CARD TEST" then press OK then press STOP. Pls let me know if this trick worked.
Posted on Oct 06, 2007
  • 1 more comment
  • agustin Feb 16, 2008
    Try this little trick that I have discovered. Press START for 4 seconds, then you will hear 2 beeping sound. Then alternately press STOP and START 4 times. You will see a cursor like display on the right side of the LCD. Press MENU or FUNCTION then input 97. Look for "CARD TEST" then press OK then press STOP. Unplug the device then plug it again. A new icon will appear on the display.
  • mai777 May 10, 2011
    nice ! I now copy and print without plug'n print card, reusing reeled back inkfilm.
    on a "Philips magic 3 basic" with a PFA331 plug-n-print card do the following to
    disable any future check of chipcard.
    press START 4 sec. until the beep. press MENU then type 94 and scroll to TEST CARD.
    set it to zero. open case. remove the plug-n-print card.
    I now was able to reuse the spent inkfilm, (scrolled back onto further reel) with no chipcard in place. excellent ! the inkfilm-meter will show NEW INKFILM! very nice hint by augustin. what are the other MENU 97 good for, you think? there are 6 more setting to tamper with but I don't want to screw it up. many Philips faxes have this "secret menu" for hacking !
    I ran into the problem when the fax said : "chipcard says: inkfilm is spent" buy a new one. But I did not feel like buying a new one, since the inkfilm can be reused a few times if you accept some lower blackening at times.
SOURCE:
PHILIPS magic 3 with PFA331 inkfilm plug'n print
Mine come up with replace ink film when I do this how can I get past?
May 10, 2011 | Philips Office Equipment & Supplies
Tip
Hidden service menu
some faxes, such as Philips primo / magic 3 have hidden service menus.<br /><br />There in menu 97 submenu CARD TEST 1 you can turn off the plug-n-print card such as PFA331. now you can spool back the inkfilm for reuse and sell your unspent chip card at ebay.
on May 11, 2011 | Philips PPF-531 Plain Paper Thermal...
Tip
Disable chipcard check and print forever
to do it, press and hold START 4 sec.
press STOP/START 3x over
enter MENU 97 , scroll (arrow right) to CARD TEST 1
enter 0 (zero) to turn it off.
press OK.
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
How to replace the inkfilm in my Philips Magic 5 Primo?
hi, how do i register my cordless phone. because i donot have any dial tone.In the book said the cordless tel does not registered with the device. at the moment cordless screen displayed please register. Pls help me how to solve. thanks. khokan
Aug 10, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
How do we fit the refill inkfilm ribbon
The fax is usually indicated on the film compartment and also the film , check on the two places but remember to remove the seals.
Dec 02, 2009 | Office Equipment & Supplies
How to replace inkfilm in magic 5 primo fax
HI it will tell you how to replace the ink film if you buy a new one, it has instructions on the box.
Feb 25, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Philips Magic 5 fax/copier/phone
Take the Sim card out and put it in again.  Worked for me.
Sep 11, 2008 | Office Equipment & Supplies
Phillips magic 3 fax machine
in this situation i advice you to refil ink jet because ink consumption depends on the size of black area in the document and high black area will absorb the ink.
Mar 06, 2008 | Office Equipment & Supplies
Philips PPF-531 Plain Paper Thermal transfer Fax Logo
693 people viewed this question
Top Philips Office Equipment & Supplies Experts
Damen Wong
Damen Wong
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
