Question about Photography
Free onan k1000 tag-along manual
Repair manual
Where can i find a repair manual
Onan's website has them. I don't think you can get one for free, though.
May 29, 2016 | Onan Microquiet 3600 & 4000 Generator
Have a k450 onan gen will only run with choke almost closed
My K450 onan tag along was doing this and an adjustment of the governor set screw ( voltage +/- )cleared it up.
Oct 01, 2013 | Electrical Supplies
Free Service Manuals
What is the question? You want a free service manual?
May 07, 2013 | Onan Marquis Gold Quiet Gas Generator 5500...
I have a pentax k1000 35mm slr camera. the light meter wont move from the middle even when I put the camera up towards light and change the aperture size. I took it to a shop quickly and I was told that It...
The light meter has failed.
You can usually get it repaired (it's even possible to do so on a DIY basis if you're fairly handy, just search "k1000 meter repair", click here for one immediate possible fix), but it may be cheaper and easier to obtain a handheld light meter instead.
If you do get it repaired then at the same time get a full CLA service (Clean, Lubricate, Adjust) and have the gooey foam light seals replaced. Some repairers may try to charge extra for the latter one-off job, but usually do it for free when you smile and politely point out that you can take your business elsewhere.
Although simple and very basic, a good clean K1000 in a freshly serviced and fully functional condition is one of the only Pentax 35mm SLR's which is still worth reasonable money simply due to high demand for them. If you choose to keep it then it should be good for many more years of flawless service.
I hope that I've helped, please rate my answer.
Feb 23, 2010 | Pentax K1000 35mm SLR Camera
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Missing battery cap
I lost the battery cap of my K1000 on vacation...I replaced the battery and taped it snugly in place with a bandaid. It hasn't budged in a year! Just find a good strong tape and tape over the battery.
Aug 26, 2009 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Scratched Negatives
When you say ''back'' of the film do you mean on the emulsion side or the base side. Base can take light scratches can may desapear in processing..Emulsion side is not forgiving...
Hard to tell..Anything along film path can cause scratches, including the back of the cover, film tension, aperture gate..
Hard to suggest anything precisely other than a good check up by registered Pentax rep.
I once spoted a similar problem by loading a camera with he film wounded backwards. That is emulsion facing the back of the camera and base toward the lens. Emulsion being softer, I found a spot where emusion built up (thus scratching on base side). I did not dare fixing it and sent it for repair for a good clean up.
Under proper lighting, you may also want to remove the lens and carefully look for the scratch in the aperture gate. If you see it, problem is before (feeding side).
Good luck. KX is aging but still a good camera
Mar 22, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 camera
VGDHDTH HNTFHDT VGJFT GJ ME MAY
Dec 19, 2007 | Cameras
Film advance
I don't suggest that you attempt to repair this yourself. The K1000 is a very solid camera and one that isn't very expensive to repair. Please do yourself a favour and take it to your local camera repair shop. You'll be glad you did.
Apr 16, 2007 | Pentax K1000 35mm SLR Camera
Photography Logo
264 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
