Question about GoVideo VR3930 DVD Player/VCR
Dowes this machine transfer vsh tapes to dvd
Can you transfer tapes to dvds using this machine
    Problem Solver:
  • 5 Answers
This machine is capable of DVD to VHS and/or VHS to DVD dubbing.
Posted on Feb 24, 2012
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
Can I copy a vsh tape to a dvd with this one player
You can't. It's designed to copy DVD to tape. You might want to invest in a little device: Audio Video USB adapter convert VHS tape to PC, CD, DVD. About $20.00 or less.
Apr 06, 2012 | Zenith XBV342 DVD Player/VCR
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
How can i convert tapes to dvd
You can connect the Camcorder to the Computer using A/V interface to transfer the recordings to Computer.
Once you transfer the recordings from tape to computer, you can use any burning software to burn the recordings to DVDs.
In order to capture the analog videos, you can use the Windows Movie Maker available in the Computer.
If you need further assistance please click hear to reach me..
HOping a positive thump after your issue is solved.
Jan 13, 2011 | Sony Hi8 CCD-TRV138 Camcorder
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
Transfering 8mm video tapes to dvds
Hi there. You need to transfer your videos to your computer and then burn them to DVD using a program like Record Now, or Nero. You should be able to get this from Best Buy, or you can get it online from their websites. If you have any other questions, let me know with a comment. Thanks for coming to FixYa.
Rob
Mar 03, 2009 | Sony Handycam CCD-TR517 Camcorder
How to transfer movies from VHS tape to DVD.
i hate being the bearer of bad news, but your unit is a dvd player only, not a dvd recorder. it cannot burn dvds, and so you cannot use it alone to transfer your home movies to dvd.
again, sorry...
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I transfer hi 8 tapes to DVD without the working camcorder
Greetings jamhere,
I have the same issue myself with my gillion of family tapes and my Hi8 unit broken! The only remedy I have found is to either invest in a new lower price HI8 unit, rent a unit and get my transfers done, or pay to have the old tapes put on dvd professionally. None of these options are too appealing to me, but really seem to be the only options available. If only HI8 had an adapter like VHS-C! I personally would look on some of the online resellers to see if you can obtain a unit that is lower priced to meet your needs. Investing overall in a Hi8 as your only camcorder is not advised, due to it being almost obsolete technology.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
May 05, 2008 | Video Cameras
GoVideo VR3930 DVD Player/VCR Logo
186 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
