Question about Sony Playstation 3 (PS3) Console
My problem with internet
Whenever i plug my internet cable at the back of my ps3
the light dont turn on and there is nothing wrong with the cable
because i always plug it to my laptop and it works...can you help me?
  • mrtwo7 Oct 29, 2008
    internet dont work green light doesn t come
    Novelist:
  • 111 Answers
Hi there Case,
it seems like your PS3's Motherboard could be the problem with you not being able to connect, either their are faulty connections or damaged wires which connect the Ethernet port directly to the motherboard itself, if your PS3 is still within its warranty i wouldnt advise attempting a DIY remedy to the problem, instead i would suggest calling sony customer support and asking for advice to see if they can sort out a repair or replacement of your system
Hope this helps !?
Posted on Oct 28, 2008
At&t tv and internet doesnt work when i plug in my PS3 (first gen. 20gb) even when the PS3 is turned off the cable and internet still wont work when the PS3 is plugged in an outlet i have to unpluged...
dont worry it seems to be a small problem................. and u can easily resolve your problem Click Here to download the repair guide dont waste money by going to repair shop........... with out knowing much you can repair your ps3 with the help of this guide .........
it covers this problem so can download this soon to resolve this problem
Jun 24, 2010 | Sony Playstation 3 (PS3) Console
When i try to do the internet connection it says succeded for the ip adress but it says failed for the internet connection. i have a cable modem
Assuming that you are plugging the PS3's network cable directly into the cable modem itself (not using a router or switch).
Try using this procedure:
1) Power off the PS3 and turn it off from the back (so all the lights are OFF).
2) Unplug the power from your cable modem for 20 seconds then plug it back in and WAIT for ALL lights to start flashing like normal.
3) THEN restart the PS3 and retry the internet connection procedures.
That should resolve the issue.
the GEEKsters
818.306.3012
info@theGEEKsters.com
www.theGEEKsters.com
Oct 09, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
I dont seem to know how to get my ps3´s wireless keypad working.
Hit the reset button (its the little hole on the left of the back). It works all the time.
Mar 02, 2009 | Sony Playstation 3 Wireless Keypad/Mouse
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Connecting to the Internet
Turn off the PS3, unplug the power to the cable modem, let them sit 5 mins. Plug in the power to the cable modem ONLY, wait for all lights to be on steady except for the activity light Then turn on the PS3 and check the network IP addy.
Sep 14, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
