Question about Cameras
Power on . lens comes out . blank screen - Cameras
    Problem Solver:
  • 8 Answers
Now a days, many cameras come with an option to switch off the LCD ( to increase the battery life ). So, check for it. Usually, pressing the 'display' button (if there is one) would solve the problem.
Posted on Oct 29, 2008
When I click the button to take a picture the screen goes blank and doesn't come back on. Power light is still on.
Your shutter is stuck open. Remove the lens. Set to fireworks mode. May need to be in a dark room. When you press the shutter button tap the camera with an object that won't damage it. I used a rubber coated knife handle. Pull the battery and repeat. Tapping all around the camera. Hopefully it will break free. Then do some continuous shooting to loosen it up.
Nov 27, 2011 | Olympus PEN EPL1 Digital Camera
Nikon P60-Screen is blank and lens doesn't retract.
Please remove the battery for few hrs and charge them after that replace the battery and try to power on if the problem persist then take to any service center the firmware needs to be updated or there is some short in the circuit board of the cam.
Feb 16, 2010 | Nikon COOLPIX P60 Digital Camera
The LCD screen comes on but is blank. Cannot take or retrieve pictures.
Hello my friend,
Did you drop the camera ?
Basically this can be Lens broken or screen broken. you can check that by:
1. try to move your hands around the lens and see if it will change something. 2. take a picture even tough the screen is blank and then take the memory card and insert it into your computer, if you can see the picture on your computer that means the screen is broken. but if you cannot see the picture on PC that means the Lens is broken.
Oct 29, 2009 | Samsung Digimax S630 Digital Camera
Will play some discs but mostly it won't, comes up with 'No Disc' message but sometimes ther is just s blank blue screen.
hello ! there is a problem in the Video section (video card  circuit board) need to be changed . thats why sometimes there is no display .
Or the lens is not getting to its position to read  or lens has weaken  u can try to swap lens  just to see the reading power .
Even lens cable could be damaged because of back forward movement ,get  a new cable and see if the lens is moving up down
if nothing change the lens .
good luck
Oct 16, 2009 | Denon S-301
When i turn my camera on, its a blank screen with
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
WEIRDEST PROBLEM
Your battery may be low on power.
Buy new batteries.
Jul 13, 2008 | Olympus FE-170 Digital Camera
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
