Question about Kenwood Car Audio & Video
How to bridge a kenwood kac-9105d - Kenwood Car Audio & Video
    Habit-Forming:
  • 15 Answers
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Posted on Feb 24, 2012
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
tonydunagan
  • 9 Answers
SOURCE: i was playin my subs
Popped fuse! Replace it.
Posted on Oct 26, 2010
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
SOURCE: help
i agree with the person who said that the ohmage is lower than the 4 ohm, but also check to see if your voltage drops lower than 10 volts it used to happen to mine and the fuse kept blowing
Posted on Aug 04, 2009
SOURCE: HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI
Es un monoblock amplifier, esto significa que el amplificador es de un solo canal, y este tipo de amplificador no se puede conectar en bridge.
Posted on Aug 16, 2009
No sound from my subs
it should have a red light on if it is in protection mode. If it does not have the red light then buy a new amp and check all you wiring
Nov 22, 2013 | Kenwood KAC-9105D 1800W Max Class D 1 Ch...
Kenwood kac-9105D amp
Tipical for that amp.Did you buy it used?
Oct 27, 2012 | Kenwood KAC9105D Car Amp
I have a Kenwood KAC-9105D amp. It is brand new and worked for about 20 minutes while I was driving and it hasn't worked since. When I turn my car on, the blue and red LEDs on the amp both come on for a...
First of all, how are your subs wired to the amp. Make sure your amp is not bridged or you'll fry it, it only has one channel. If that doesn't work you probably already fried your amp.
Oct 09, 2010 | Kenwood KAC9105D Car Amp
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
KAC-9104D Car Audio Amplifier: how to bridge...
Sorry this is a mono amp, you cannot bridge one channel
May 17, 2010 | Kenwood KAC-9104D Car Audio Amplifier
HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI KENWOOD KAC X1R??
Aug 11, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Car Audio & Video Logo
1,071 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
