Question about PQI Electronics - Others
My pqi sd card corrupted
My pqi Mini SD card corrupted
  • 119 Answers
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
Posted on Jan 08, 2009
webmaster21
  • 803 Answers
SOURCE: my mini sd card is in raw format and my computer
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Posted on Sep 25, 2009
  • 10406 Answers
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
SOURCE: how can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
Posted on Aug 28, 2010
IceCake
  • 68 Answers
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
Posted on Oct 02, 2010
How to unlock camera samsung ES30 2gb sd card
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Dec 26, 2012 | Cameras
Why dont my micro sd chip work
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab toward the pins to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
Sep 19, 2011 | PNY 2GB microSD Memory Card
I got a Micro sd card 8Gb an then I wanted to put in the computer to move files, tells me that I have only 228 kb of free space and is empty. What can I do ?
the lower right hand side of the picture a slot that says "write protect", move that tab towards the pins to unlock the card.
Aug 27, 2011 | PNY 2GB microSD Memory Card
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
My card is not working
Feb 17, 2011 | PNY 2GB microSD Memory Card
How do I download photos from LG VU (CU920) cell phone to my computer?
you can use the bluetooth feature if your computer also has bluetooth capability. if not, hopefully you're using a mini SD card. if your computer has a port for mini SD's, then just take the mini SD out of your phone and plug into your computer. if your computer has a regular SD port, then you need to get yourself a mini SD adapter. it looks just like an SD card, but it has a small opening to slide your mini into. if there are no SD ports on your computer, simply buy yourself a Flashdrive (thumbdrive) that has a port on it for mini SD cards. then, just plug that into your USB port.
if you're not using a mini SD card in your phone, then you need a data transfer cable, which you probably have to get from AT&T. i tried radio shack, but they didn't have them. In my experience, using a mini SD card provides the most compatibility. hope this helps.
Feb 06, 2010 | LG Vu CU920 Cellular Phone
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Cant reformat memory card mini SD
to solve thix problem you have to format your memory card through computer
then reformat it on mobile
Jan 14, 2009 | Nokia N71 Cellular Phone
Putting music on cell phone
MUSIC
This menu needs to be supported by mini SD Card.
It plays the music stored in the mini SD Card.
Copy the downloaded music from PC to mini SD Card,
and play the music stored in the mini SD Card through
your mobile phone.
Store music in the mp3 folder on the SD card.
1. Press [MENU] .
2. Scroll through the downloaded music to display the
music you want.
3. Select the music you want to play then press
[PLAY] or press [MENU]. Then select “Setting”,
press [OK], then 1.All Repeat, 2.Repeat,
3.Random.
Press [OK].
  • “mini SD Card” is connected to your phone, press
[MENU] to select 1. Setting, 2. Erase (Erase This/
Erase All), 3. Information.
Mar 30, 2008 | Audiovox CDM-8940 Cellular Phone
Electronics - Others Logo
24 people viewed this question
Top PQI Electronics - Others Experts
Lawrence Oravetz
Mithilesh Kumar
Tom Currie
Tom Currie
Level 1 Expert
Are you a PQI Electronics - Other Expert? Answer questions, earn points and help others
