Question about Hotpoint Washing Machines
Hotpoint washer top loading has oil dripping on the floor
I just bought a house (14 years old) and just recently the washing machine has its oil dripping on the floor. what is wrong with this? can i repair it? if not, is repairing it costly?
  • 1,543 Answers
The only place oil can be coming from is the transmission. If left as is, leaking oil will eventually result in full transmission failure. Yes, you can replace the transmission, but the repair is costly and moderately difficult. I'd save the expense and put the money toward a new machine. Please don't bother rating this solution as anything but a FixYa will drop my rating.
Posted on Oct 28, 2008
I have a Maytag Atlantis top load machine. It is 7 years old. I have very dark oil dripping from under the machine at the bottom edge of the front. I am assuming the gear box is gone but wanted to confirm...
Sorry to confirm your suspisions but its leaking oil from the transmission and its exxxpensive to replace the transmission. And sad but true the good ole days of dependabilty of the maytag is gone espically since 5 years ago Maytag was bought by Whirlpool. a Whirlpool is a good machine but nothing was good as the old Maytag's
Aug 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Black oil spots on white clothes after washing
your top transmission seal is leaking oil out of the transmission,and its getting forced up thru the tub seal this condition is called "back-wash" you need to remove the tubs both inner and outer to access the seal,it takes time
Mar 21, 2010 | Hotpoint VBXR1090D Top Load Washer
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Leak underneith washing machine
Tip washer to inspect belts & hoses on bottom. Check hose connections & plastic pump housing for crack.
Nov 04, 2009 | Westinghouse WWS833ES Super Capacity Top...
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
