Indesit wil95 oppreat book - Washing Machines
What to do with F13 error indicator on my indesit washing machine please.
Dryer temperature sensing fault (washer dryers only)
Issue: Washer dryer is not drying clothes.
Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Mar 31, 2017 | Indesit Washing Machines
Indesit WIE127 is blinking
it needs resseting have you got the hand book as it will tell you how to if not let me know and i will look though mine and tell you how
Dec 07, 2011 | Indesit Washing Machines
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
Error code a14 on indesit evolution de73
A fault with the water heating has occurred. Book a service engineer
Sep 07, 2009 | Indesit 24 in. DE73 Evolution...
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
Jun 10, 2009 | Washing Machines
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
