I have INTEX IT-5800W Home Theatre (5.1Ch). I want to set Stereo Sound in that. Pls tell me how can I do the same.
INTEX
2 Suggested Answers
tech240
  • 169 Answers
SOURCE: probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Posted on Apr 25, 2008
Roku sound
Most common problem I have run into recently is that there are a lot of home theatre and tv units that don't support Dolby 5.1 plus, 5.1 works fine but most of the show on netflix are using 5.1 plus now.
easy fix for now, when you start a show on Netflix go down with the arrow button and set the audio to (stereo). I currently have that problem as my home theatre supports Dolby 5.1 but not 5.1 plus.
I'll be checking the Spec's on my next home theatre receiver to see if it supports 5.1 plus.
hope that helps, good luck
May 13, 2014 | Televison & Video
I cant get my theater system to work right only two speakers work, d o i plug into the back of directv reciever box
If only two of the speakers out of all are working, there is a possibility that your system is set to stereo audio instead of 5.1 channel surround sound. The easiest way to check and fix this problem would be to look on your remote control for the audio or "surround" button, and press it.. A notification should come up either on screen or on the unit itself, and tell you whether or not it is on Stereo, or Surround Sound! Hope this helps, if that doesn't fix your problem please post back!
Aug 28, 2011 | RCA RTD300 DVD/VCR Home Theatre System...
I am having 21 inch onida black 200 tv .I have recently bought philips home theatre. please let me know how to turn off internal speakers of onida tv and how to turn on external speakers to send audio...
By the looks of it, the only output you can use from the tv will be using the 2.5mm jack plug headphone socket, get a cable to convert this into twin phone (red/white) for stereo sound to your amplifier. (they are very cheap £2 or so) The Home theatre system should be able to give you a psuedo surround but you wont get full surround.
May 02, 2011 | Audio Players & Recorders
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Is-lcdtv32 and Home Theatre
run all of your components through the stereo first and just bring the video out of the home theater
thanks
scott
May 29, 2008 | Insignia IS-LCDTV32 32 in. Television
Connet to pc
Well, I would have to know what connectors your sound card and home theatre system have. If you dont have a sound card, get a headphone/3.5mm trs plug to stereo rca plug adapter usually available at your local radio shack or walmart, and connect to the red/white rca plugs on your reciever. If they have other connectors(your sound card/ home theatre system) you might try coaxial digital audio-S/PDIF or optical S/PDIF.
Dec 25, 2007 | Durabrand HT-3915 System
HOME THEATRE SYSTEM
I think you must change the settings and try it out! it will make a great change.
Dec 07, 2007 | Audio Players & Recorders
How do I connect Sharp XR-10XL projector audio output to a Sony Home Theatre System DDW795?
Dear Sir,
Pls take The output from the projector in the stereo format and connect thru thru the approriate cable to your Sony Home Theatre System DDW795 on audio input.
Virender Dhiman
Nov 30, 2007 | Sharp XR-10X Multimedia Projector
87 people viewed this question
 Grubhead
Grubhead
