Question about RTO Sole F80 Treadmill
Sole f80 treadmill buttons don't work - RTO Sole F80 Treadmill
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
  • 156 Answers
SOURCE: We can't get our F80
Is the motor running? Even if the light comes on doesn't mean the motor is turning on.
Posted on Sep 19, 2010
ercupa190
  • 12223 Answers
SOURCE: motor is not responsive and it read LOW SPEED message and time L51
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
Posted on Dec 09, 2011
  • 33 Answers
SOURCE: I have a sole f80
hai , check communication cable, speed sensor
Posted on Dec 10, 2011
Shows LS1low speed treadmill stops working what is the solution
hi check the video
Sole F80 LS1 Error
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Nov 16, 2015 | Sole Fitness F63 Treadmill
My fan quit working on my Sole 80 treadmill. Everything else is fine. Any suggestions to fix it?
The display pcb board is bad. Replace internal Display board. Might be expensive.You can get used parts at www.usedtreadmillrepairparts.com
Jan 01, 2014 | RTO Sole F80 Treadmill
Sole f80 stuck elevation
LUBE the gear and shaft motor
2) test the input voltage motor, see the diagram attached, if there are the motor need repair.
3)see if there are some relais, and clean for dirty, oxide, or coil. open and replace.
see the block diagram
Run the software calibration for easy diagnose, and troubleshooting.
God bless you
Nov 23, 2012 | Fitness Giant Sole Fitness F80 Folding...
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
May 15, 2012 | RTO Sole F80 Treadmill
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
RTO Sole F80 Treadmill Logo
307 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
