Question about Rinnai Heating & Cooling
Converting rinnai 516tr from natural gas to lp
Is the rinnai 516tr natural gas heater able to be converted to lp gas, is it worth doing? not sure how old
  • hback Feb 25, 2012
    Yes local gas company can fix it for Aus Dollars $220 and there are still kits available & I paid $85 for the heater, and I would never attempt myself some things are best left to the professionals. I am happy with the outcome hope this may help other people.
  • Rinnai Master
  • 2,464 Answers
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Posted on Feb 25, 2012
roniecon
  • 6826 Answers
SOURCE: Can the Dayton model 3e368e be converted to use
If you know a dealer or repair company,they can order orifices to change out in the unit.
Posted on Oct 17, 2009
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
vortash
  • 431 Answers
SOURCE: Rinnai 560PTR Heater Converted Propane To Natural Gas No Ingition
I think you will find the thermocouple or thermostat has gone this allows the gas valve to open and is a saftey device to stop the escape of dangerous fumes .. it looks like a long piece of thin copper wire approx 4mm thick and it extends from the main valve into the pilot light flame .. When the ignition is pushed and you hold your finger on it for a while this tells the the valve that the pilot light is lit .. conduction of heat along this pipe then opperates the diaphram in the valve allowing the gas to the burners the pilot light then ignites them .. if the pilot light goes out the unit will nort run ..
My advice to you is that even though you may be conversant with the heater .. they do tend to have all manner of faults occur when left in storage or if shipped ( jostling and bumping ) is to get a trained gas engineer to check it out it may cost a bit .. but a gas escape and the following reprocussions are far more exspensive and costly .. Also You may not be aware that if you do have an incident your house ,insurance may be null and void if no service documents can be raised for the correct servicing of a fixed or mobile gas Convector .. I hope this helps Regards Vortash
Posted on May 22, 2009
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
SOURCE: Rinnai Convector 404 Natural Gas
I have a natural gas unit. do you want to swap? 0407284314
Posted on Dec 26, 2009
I have inherited a rinnai 516tr heater how do I tell if it is lpg or natural gas
There is a makes plate on it which say NG for nat gas or lp for lpg
Jan 07, 2013 | Rinnai Vent Free Gas Heater/
Can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
Aug 01, 2012 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Is it possible to convert a rinnai avenger 25 from natural gas to lpg?
Yes it Should but you will want to check with manafactuer because it will need a conversion kit for lp gas. Natural gas is a different p.s.i. than lp gas so don't try without conversion kit. It should be just a small fitting that goes inside the gas valve. Hope this helps have a good day
Aug 12, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can model no. REH-20-P be changed to natural gas?
Since it's a Rinnai Vent-Free LP Gas Heater .. No, it can not be converted to Natural Gas. No Vent-free Gas Heating Appliance can be converted from one gas type to another. It's not just Rinnai.
Mar 10, 2011 | Heating & Cooling
Can I convert a Rinnai natural gas water heater to LP.
A registered gas installer can obtain parts through Rinnai stockists and convert most heaters.
Feb 22, 2011 | Rinnai Digital Remote Water Heater Control...
Just need to no what is required to convert a Rinnia energy saver 1001ft space heater from natural gas to LPG?
hi change the burner injector and the pilot and the reg or the spring inside , you should be able to buy a kit for this.
May 07, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Apr 23, 2009 | Kitchen Ranges
Converting Rinnai REH-25-N to LP
Typically, an unvented heater or gas log cannot be converted, mostly for safety reasons and it is usually cost prohibitive. Some newer heaters come with both Natural Gas and Propane components and have to be set up one way or the either.
It would be better to sell your old heater and get one with the proper gas type.
Nov 23, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
672 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
