Question about Camping, Backpacking & Hiking
Replacement globe for a 1960's thermos portable gasoline lantern
I need to find a replacement glass globe for a very old lantern made by Thermos. It has to be 4 1/2" high and 5 1/4" on top and 4 1/4" on bottom. Can you help me?
  • trailwing196 Jan 25, 2009
  • 29 Answers
Hard find.........www.ronfoo.com
This guy may be able to point you in the right direction being an antique/collector's item.
GGBMDB
Posted on Dec 02, 2008
REFILL NO 14 OF, CAPACITY 1 LITRE, REF NO 91Q (T91Q). I live in ORPINGTON, KENT, ENGLAND. many thanks.
This may be a simple case of a web search using Amazon com Online Shopping for Electronics Apparel Computers Books DVDs... , eBayeBay or sites like Appliance Spares Accessories, but a quick visit to Thermos themselves and follow links to spares. good luck.
Apr 21, 2016 | Miscellaneous
What to do when stanley thermos no longer keeps my coffee hot . is there any way to fix it.
thermos cant be fixed once the glass gets punctured. it is cheaper to buy a new one
Nov 23, 2012 | Stanley Classic Thermos 10-01229-001 24 Oz...
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
I need a regulator valve for a thermos grill2go bbq model number UK-467638503,PART NUMBER 4158176
Jul 29, 2011 | Thermos Grill2Go Gas Grill 4656110
How to install new mantles?
First of all, make sure your lantern is completely shut off and cooled down, and you are working in a well ventilated area away from any external fuel sources.
You need to remove the screw holding the top cap on, then remove the top and the glass globe.
Then remove the remains of the old mantle(s) and then tie on the new ones in their place.
Then, with the lantern fuel supply turned OFF, carefully light the mantles with a match or lighter and allow them to completely burn to ash and the flame to go out. Do not touch the mantles after this point because they will be very fragile.
Now carefully replace the glass globe and screw the top back on.
Now you can try lighting the lamp normally with the fuel valve in the ON position.
Here are a few links to some short videos on YouTube which demonstrate the mantle replacement process:
http://www.youtube.com/watch?v=_6lLNFcwsEk&NR=1
http://www.youtube.com/watch?v=8qRPe8V1tC4
http://www.youtube.com/watch?v=YHBxgx_BNF0
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 16, 2011 | Coleman Northstar Dual Fuel Lantern
What fuel does my 335 lantern run on pat no 1969 globe 4,mantle 999 generator 63 0n bottom fuel tank has a no 937416 and year 1969 any information would be great
happytimes17-
This lantern is designed to run on gasoline, but will work best with white gas, also generically known as "coleman fuel" in many areas. White gas is in fact a more pure form of gasoline, without many of the fine particulates and impure distillates found in automotive gasoline.
Most hardware stores and sporting goods stores carry Coleman or other brands of white gas.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Sport & Outdoor - Others
I need a replacement stopper for my thermos s/s
Hi I did a search and found your flask supplier and also found that yours has a 5 year warranty, so here is where you can get help to replace your stopper, if you go to this site you can contact thermos direct
http://www.thermos.com/contact.aspx
if your in the uk simply go to www.thermos.co.uk and go to the support or contact page, if they cant directly replace it although no reason why they shouldnt, they will be able to tell you where you can get one, hope this helps
Jul 27, 2009 | Thermos Stainless Steel Bottle with...
How to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
Replacement part for Thermos Nissan Coffee Maker
Call Thermos Nissan direct at 1-800-831-9242. Replacements were $3.75 each plus shipping at the time of this posting. Shipping is about a week.
Apr 23, 2008 | Coffee Makers & Espresso Machines
Camping, Backpacking & Hiking Logo
712 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
