Question about Video Cameras
I have a 1990 dodge d250 that seems to loose fuel and dies randomly
I have a 1990 dodge D259 with a 318 with throttlebody and automatic. I live in alaska and had it warming up the other day and when I went to leave the truck had died and wouldn't restart. it has over a half a tank of gas, but the fuel seems to shut-off. I have changed the fuel filter, fuel pump, engine computer, coil, cap and rotor, and alternator. and it will start but will cut-out and die at ramdom intervals. I also run heet in my fuel all winter so water shouldn't be an issue.any help would be greatly appricated.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Video Cameras Master
  • 102,366 Answers
You posted this question in the camcorder area of FixYa. Please repost it in FixYa's cars and trucks area, so that appropriate experts can see your question and provide a solution.
Thank you for using FixYa.
Posted on Feb 24, 2012
I have a 1990 Dodge Dakota/3.9/2wd and I believe that my choke stopped working. When it's cold I have to feather the gas pedal until it is at about 100 degrees before it'll idle on it's ow
replace the TPS ,@ throttlebody, throttle position sensor, either needs replaced, or the 2 bolts that hold it on came loose, sensor needs to be turned a little , to increase throttle, then retighten bolts. should also tighten the throttlebody bolts to intake manifold,
Feb 05, 2013 | 1990 Dodge Dakota
The car will start and even run idling for 20 minutes no problem, but as soon as I drive it a couple of miles it dies and wont start. If I let it sit for a cuople of hours it starts again. Any ideas?
Check all the vaccum lines and throttle body make sure its not to drity.the throttlebody air intake plate sounds like it is sticking open if so clean it out with throottlebody cleaner.and it should run good if not your fuel pump maybe going bad wish I could look at it goodluck
Dec 04, 2011 | 1998 Pontiac Grand Am
My acer d250 doesnt switch off automatically?? what is the solution can you please tell me.
it must be programed to go into standby. log in as administrator, go to control panel, power options-advanced-when i press shut down & select shut down
Dec 25, 2010 | Acer D250-1990 (LU.S670B.171) Netbook
1997 dodge ram 5.9 fuel pump troubleshooting truck ran fine was low on fuel stopped it went to restart n wouldnt fire poured gas in throttlebody n truck fired off n then died
If the pump has run down on fuel and the fuel pump ran DRY , then it is possible that there is air in the system and the flow can be restrictive. The fuel lines have to be opened out to allow the flow till the air moves out of the system.
The fault will clear one the pump clears this fault .Now you can connecct back and start .
Aug 29, 2010 | 1997 Dodge Ram
My 1990 GMC sierra pu dies randomly while driving or even sitting. Seems to be more prevalant when raining but now does it all the time.
COULD BE BAD IGNITION COIL OR MODULE.IT COULD BE BAD FUEL INJECTOR OR INJECTORS.CLOGGED FUEL FILTER. A BAD DISTRIBUTOR CAP ROTOR + BAD PLUGS AND WIRES WILL CAUSE PROBLEMS AND BAD FUEL WITH WATER IN IT.
Mar 01, 2010 | 1990 GMC Sierra
I have a 1990 Dodge D250 seems like the gas is not flowing keeps cutting off unless you pump it
could be the fuel filter or the fuel pump filter. Both of those could keep u from getting enough gas to stay running withou pumping it
Mar 25, 2009 | Dodge Ram 250 Cars & Trucks
How to change 1988 dodge b150 1/2 ton 5.2L throttlebody fuel injection to multiport fuel injection
you should swap complete engines and ecus i have seen this set up installed in a 1938 dodge truck so yes it can be done
Oct 17, 2008 | 1988 Dodge B150
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
