Question about Thermador PGR366 Gas Kitchen Range
How to convert thermador pg366blp to natural gas
When I bought this stove my original intent was to buy a gas stove and an lp conversion kit. For some reason the thermador sales rep felt it neccessary to talk me out of it. He suggested that the only difference between buying a ng model and converting it to lp and buying an lp model and converting it to ng when ng became available was when I would have to do the work to convert. This wasn't a hard case to make because I had just buil the house and was sick to death of working on it. So I ordered the factory propane model and a ng conversion kit. The kit got dropped off of the invoice and when I tried to reorder it they would just drop it again and tell me I never ordered it when I inquired. I finally gave up until the time came when ng became available to me. Now they say such a kit doesn't exist and that the model of stove I bought cannot be converted. This leaves me in a real pickle because I can't afford to replace the stove, since it is a 36" stove and I have 36" space in my cabinets there are no cheap stoves I can run out and replace it with just to get by. Also as you can well imagine a $6000, 100,000 btu stove that can only run on propane is going to be hard o get rid of, especially with propane costs at an all time high. My real question is is it just a matter of oriface size? Because I'm more than capable of drilling out an oriface I just can't get anyone to tell me if anything else need be done. Is my stove really built completely different than the ng model? Because it really doesn't make sense from a manufacturers standpoint to do that. If so can I just buy the components to make it a natual gas range? Anything would be cheaper than buying a whole new stove.
  • 1 more comment
  • jemolia Nov 25, 2008
    i would like to know the same thing but from gas to propane
    for a 48"
    duel fuel
    any info please
  • Anonymous Mar 18, 2009
    same here
  • debbiegar562 May 11, 2010
    Just wondering if you resolved your issue. I am having the same issue. thanks
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Thermador PG484GGBS: How to convert from Natural Gas to LP?
Hello Amvmotors,
I understand that you want to convert your Natural Gas unit to LP (Propane) gas you will need to purchase a conversion kit. Please give me about an hour or so and I will locate it and the instructions to convert.
Thank you for choosing FixYa.com
Justin
May 17, 2011 | Thermador PG484GGEBS Stainless Steel...
Want to convert from natural gas to lp propane
A conversion usually consist of new burner(s)/nozzle(s)/orrifice(s) and either a new regulator/gas valve..
Some gas cook stoves or ranges come with the ability to run on either fuel and the spare nozzle or orrifice will be attached somewhere on the stove.. usually under the range top.. the gas valve may have a small lever that you simply move to the preferred fuel setting.. NAT or LP.
The appliance must have a rating plate that states it can be converted.. and if so..typically a conversion kit will be available or may have been included in the appliance package.
LP Gas runs at a higher pressure.. making a broad statement here.. converting from Natural to LP is more dangerous if the proper steps are not followed then converting from LP to Natural.. which typically just results in a weak flame.. regardless. it's still dangerous.
Many modern appliances will have a warning label stating it can only be used with a certain type of fuel. Heed the warning.
If your appliance did not ship with the alternate fuel kit or has a warning label.. do not attempt to convert it.. it will be much safer and cheaper to buy the proper appliance.
Best of luck.. and be careful
Mar 29, 2011 | Heating & Cooling
What is the product # for the conversion kit from nat gas to lp? who carries this item? Does the conversion kit come with a regulator?
Some Thermador ranges are not field convertable from natural gas to LP. The PRG364EDG falls in this category. If you have one that is not convertiable; you will need a different range.
The PG364GEBS is not a listed unit at Thermador; I've found it for sale at AJ Madison. Since that vendor doesn't list the conversion kit (and they sell ones for other Thermador ranges), I do not believe this is a field convertible unit.
Thermador has manuals and installation guides for many of their appliances here: http://www.thermador.com/trade/specifications-guides . Most Thermador ranges come with the installation guide, as well as the owner's guide, if you still have your documentation. Otherwise, try the Thermador site for the documentation (check if the company uses a different part number internally). If the conversion kit is available, the part number will be provided in the section on the Gas Requirements and Hookup. If it isn't, the installation guide will clearly state that fact.
Other models are convertible. The PRD304GHU uses the conversion unit: PALPKITHC. You will need to confirm your model since the number of orifices will depend on the number of burners and the low simmer feature. (The PRD304GHU is also a 4 burner with 2 of them extra-low simmer burners model.)
For units that are convertible, you can usually order the part through the same stores that sell the appliance. Alternatively, have your gas service installer order the parts. The installation guide for the conversion kit will be included in the kit. For most ranges that are field convertable, the regulator converts from natural gas to LP by rotating a cap in the regulator by 180 degrees. (Take out the part, turn it over so that LP shows and reinstall.)
I hope this helps and I wiish that I had better news for you.
Mar 03, 2011 | Thermador PG364GEBS Stainless Steel Gas...
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
Dec 25, 2007 | Thermador PG484GGEBS Stainless Steel...
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Thermador PGR366 Gas Kitchen Range Logo
371 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
