Question about CECT KA08 Smartphone
Why doesnt my touch screen work
Brand new battery and charger but does have a crack on the screen
FIX BROKEN SCREEN
It would cost more money to replace the touch screen than to just buy a new tablet pc. It cannot be repaired without putting in a brand new touch screen.
May 29, 2014 | ZEEPAD 7.0 Capacitive Touch Screen 512M/4G...
Ipod touch will not charge, brand new
Try charging from usb or docking station, if it works than your charger is broken, if doesn't i would return product to shop as its probably broken socket or something wrong with software. Anyway usually it's just a charger and than as it's new phone i would go back to shop and ask to swap for working one :) Sometimes if battery is dead it may take few seconds or even minutes till your screen turns on so after plugin in wait a while.
Hope it help
Feb 11, 2014 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Coby mp-826
throw it in the bin and buy a new one.
Dec 28, 2013 | Audio Players & Recorders
My agptek 7 inch charger doesnt work unless i push the charger in
Carefully check to see if there is something stuck in the receiving hole for the charger. It might be just a piece of paper or lint. Pull it out carefully!
Jan 10, 2013 | Brainydeal Agptek 7" 1.2 Ghz Tablet Pc 4gb...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Screen problem
hi..... this is the only way with the touch screens
  • If the touch pad is scratch or cracked , you can replace the touch screen(touch pad/Digitizer) only.
  • The touch screen have the protect film on it,please remove the protect film before you use the touch screen .
  • Before you buy this item please check your touch screen model and make sure it's same as the photo.
  • 100% brand new.
Jul 15, 2009 | O2 Xda Atom
My battery for my Casio exilim when charging is just blinking red and doesnt turn on my camera. any suggestions? new battery?
apply new fresh battery from good brand first and try to chrge it-if this does not work good the problem in charger itself.
Mar 05, 2008 | Cameras
Avic-z1 touch screen does not work
Is the screen cracked? Just a small crack can cause problems. When the screen is cracked and you touch it, it touch's some where else on the screen. I cracked mine, and I just changed it. It's pretty easy, all you need is a small phillips screw driver. Good luck!
Jan 13, 2008 | Pioneer AVIC-Z1 Car DVD Player
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
CECT KA08 Smartphone Logo
Top CECT Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a CECT Cell Phone Expert? Answer questions, earn points and help others
