Question about MSI Computers & Internet
When I turn on my computer it gives me 3 long beeps and then does nothing The mother board is a 760gm-p33
apple_rom
  • 40 Answers
SOURCE: bios recovery for mother board ecs rs482-m
http://wiki.rom.by/index.php?title=Art_of_BIOS_flashing
Posted on Oct 04, 2007
  • 27 Answers
SOURCE: continuous beep
I have looked up the code you describe. It is best is you go to the site and see for yourself. I am providing a link. You also might try removing all the cards except for the video to see if anything changes.
http://www.computerhope.com/beep.htm
Posted on Sep 25, 2008
leecom72
  • 4806 Answers
SOURCE: I have one intel 845gvsr
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Posted on Jan 05, 2009
  • 135 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
  • 615 Answers
SOURCE: computer mother board keeps beeping when i turn on
Usually it beep if the keyboard stuck or the mouse or mem...check with your cmos by clicking F1 or del after booting and check and see the mem and make sure that your mouse and the keyboard are connected and working...hope that help
Posted on Sep 11, 2009
6 long continuous beep no display my pc board
1- You need the motherboard model. It should be written somewhere on it. Here is a link to help you do that: http://www.computerhope.com/issues/ch000504.htm
2- You need to search for your motherboard's manual online. Most manufacturers keep all their manuals (even of really old models) in their support section. If not, you can try this site: http://www.motherboards.org/mobot/manuals/
3- In the troubleshooting section of the manual, you should find what 6 long beeps means.
Personally, I used to have an MSI G41M-P33 and had a 3 long beep signal with nothing else when I tried to start my computer. The manual said that it was because it could not read the first 64KB of memory... turns out the RAM (memory) slots were bad and I could never boot with it.
Apr 24, 2014 | Computers & Internet
How to locate power switch
The power switch is usually the button you use to power the computer on. It should be either on the front of top of your tower.
Apr 05, 2013 | Micro-Star 760GM-P33 - MSI 760GM-P33...
Msi bios password
If you misplaced this password, try removing the battery for a minute or so and see if that helps. Sometimes it does. I personally have special tech software that retrieves lost passwords for my customers
Jul 24, 2012 | MSI 760GM-P33 AM3 AMD 760G Micro ATX AMD...
I have a 848p-A7 motherboard with a intel pentium 4 processor. I just got everything, set up the cpu fan, and etc. but whenever i try to start up the computer, the onboard speaker keeps going off. It's a...
1. Along beep on a motherboard indicates something is connected backward such a a fan or a data cable to the hard drive.
If it is the hard drive cable then you must have pin 1 connector turn around and therefore the mother board is giving a warning.
2. You may have a power supply failure that is the power supply is not giving proper voltage to the mother board.
3. Your ram chip is not properly seated in the RAM slot or in backwards.
4. The CMOS battery to the mother board need to be replaced.
Sep 10, 2010 | EliteGroup 848P-A7 Motherboard
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Pc will not boot. power is into the power switch as it lights up when pressed to turn on computer. with the case off the fan to the power supply and fan on the processor turn for approx 3 seconds then...
check the pin assign ments on Mother board. verify that reset and power pin plugged properly,
or
*********** board circuit is touching to metal or a metal part of your cabinet.
or
clean the mother board with dry air blower so if somthing laid on mother it will be blown out.
Nov 17, 2008 | Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Computers
If it has nothing else at all installed in it, then yes it is. The long beep tells you something is not right in boot sequences.
Mar 28, 2008 | Computers & Internet
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Computers & Internet Logo
56 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
