Question about Nokia 5800 XpressMusic Smartphone
Side camera key is not working but menu icon is working please help
My nokia 5800 xm problem is side camera key is not working but menu icon in start camera working please solve side camra key please help this problem....
How do open front camera nokia 5800
To use secondary camera on Nokia XM 5800 please ensure your phone firmware is above v20 and above, To check your current firmware version dial *#0000# you can then press options > check for updates. in case it is not updated.
If the firmware is upgraded then to enable the secondary/front camera follow these steps:
1. Activate the camera by pressing capture key
2. Go to options and select use secondary camera
Oct 29, 2010 | Nokia 5800 XpressMusic Smartphone
Hi sir... my nokia 5800 XM was working good until one day when i unlocked from the side locks.....it showed scrambled lines on screen ...so i restarted many times but still it was in same condition...now...
do you mean the vertical lines???
may be there is a loose connection on your LCD or the temperature of your phone (LCD) is too cold to fix it be sure that your LCD temperature is warm (body temperature) or you can try to scratch the screen with your hands, using friction it will produce heat that makes the screen warm and stable. this solution is only temporary cure i highly suggest that you should visit any store who will provide a repair for your phone so that it will have a permanent cure!.
i hope it helps! =)
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Oct 07, 2010 | Nokia 5800 XpressMusic Smartphone
How can i get a code to unlock my nokia 5800 from korea and to be used to a different country
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM WITH F.W 20 AND UP
Aug 18, 2010 | Cell Phones
Cannot play the music
ok
just reset your phone
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up
May 10, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 xm freezes whenever i play music on it, this is a big problem especially as its an xm edition. HELP PLEASE
back up all data and perform hard reset.
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed.
Regards
Apr 03, 2010 | Nokia 5800 XpressMusic Smartphone
Upgrade your Phone's ROM using Nokia PC Suite on your computer. It could help solve your problem.
Mar 18, 2010 | Nokia 5800 XpressMusic Smartphone
I am using the 5800 xpress .Setting and some other icon missing in my phone.How can i get it back?
well u can restore your cell try this way
5800 Hard Reset
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
Mar 02, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 XM screen not working properly, I'm touching something its sawing different thing. whats probelm? Nokia 5800 XM screen not working properly, I'm commanding some think, its respond wrong....
You can try calibrating your screen using the procedure at this link
http://www.walkernews.net/2010/01/30/how-to-calibrate-nokia-5800-touch-screen/
It will be difficult to start since your screen is not reacting as you expect it to, but it sounds like the calibration is out of whack.
Feb 16, 2010 | Nokia 5800 XpressMusic Smartphone
China 5800 xm nokia not getting gprs and wap giving me
try using setting wizard to configure your gprs setting.hope this'll help.
Feb 11, 2010 | Nokia 5800 XpressMusic Smartphone
Where are the ringtones on nokia 5800
menu
settings
personal
profiles
options
personalise
click on ringtones
you will see a list of rintones on your phone
choose the one you want
bye bye
Jul 12, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
83 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
