Question about Linksys Computers & Internet
I can not connect to 192.168.1.1
I am not sure what the exact router is however a few months ago I suddenly could not port foward/ access 192.168.1.1 at first I was fine with it but now I need it D:
  • 2,260 Answers
Check the IP address on your computer.
Connect the computer to the router and check the IP address and default gateway on your computer.
The default gateway is the IP address of your router.
If it is 192.168.1.1 then try to open the setup page. Power cycle the router and see if that works.
See How to open 192.168.1.1
Posted on Feb 27, 2012
mlake33
  • 427 Answers
SOURCE: Port Forwading
Go to your routers setup page,
Go to the section labeled port range forwarding, then enter the information.
Posted on Apr 04, 2008
SOURCE: port fowarding
fixed the problem by typing in the address bar the make and model of the router and portfowarding EG: netgear nbm814x portforwarding
looked at the list of sites that had info on it a picked one and read carfully the information. did the portfowarding and set up a static ip address
works fine now
Posted on May 20, 2008
mastersaintx
  • 928 Answers
SOURCE: port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Posted on Oct 06, 2008
dante777
  • 623 Answers
SOURCE: I would like to configure port fowarding on the CISCO 857 Router
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 24, 2009
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
~hello, i using this D-Link ADSL2/2+ for about 2 month and suddenly the wireless connection fail to connect...there is no light on wireless symbol..so, how do reset the setting? thank you
Access to the router using web interface and make sure that access point is enabled. You can reset it to factory settings by using a ballpoint or paperclip to gently push down the reset button in the following
sequence:
1. Press and hold the reset button while the device is powered off.
2. Turn on the power.
3. Wait for 5~7 seconds and then release the reset button.
You can use Router Commander for troubleshooting router problem also
Sep 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Wi-Fi connected I-touch still cannot access the internet
I have to reset my wireless router when this happens to me. I'm not sure why, but I have to do this every few months.
Oct 11, 2009 | Apple Audio Players & Recorders
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
I've had problems with this too, if you have not accidently turned it off in the configuration however you should be able to hook up another machine and access it from there. You can also try another browser, for example, it doesn't work in IE but works in Firefox.
Dec 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Port fowarding and remote desktop
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Port Fowarding
Here is a listing of programs and how to forward them for your router.
PortForward
Feb 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Aug 23, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
Computers & Internet Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
