Yamaha RX-V663 wont play rear surround
First I did the auto set up with the microphone on the receiver. I obviously have them hooked up and sound comes out of them. All 7 speaker pictures are illuminated during tests. The minute I go back to a TRUEHD sound movie the surround speaker icons go away from my receiver display and no sound from them. (I tried both Iron Man and new Indiana Jones)
I have spent the last 2 hours scouring the manuals of both my Blue Ray player and my Yamaha receiver. I have the audio output of the blue ray set to HDMI and PCM(apparantly Bitstream wouldnt allow me to turn off straight on my receiver). Either way I tried both.
The receiver Rear surround is set to small x2 and I have tried every input and setting on the receiver...its says HDMI and 7 Channel Stereo in the display.
I am fresh out of ideas on why my surround speakers turn off. anyone know this problem?
  • gszeniou Nov 29, 2008
    I got the same exact issue, have you been able to solve this yet
  • theharvestyp Dec 28, 2008
    same as the others. when hooking up blu-ray to tv with hdmi, then tv to lg system through the aux. in. no surround sound.
  • Audio Player... Master
  • 5,455 Answers
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Posted on Mar 13, 2017
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
Posted on Dec 14, 2008
srinivasb81
  • 51 Answers
SOURCE: 5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Posted on Mar 27, 2009
  • 9 Answers
SOURCE: Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Posted on Aug 21, 2009
mikelpoynter
  • 77 Answers
SOURCE: How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Posted on Oct 29, 2009
Yamaha rx-v663 how to set and lock sound program
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
May 07, 2015 | Yamaha RX-V663 Receiver
I have connected a cordless microphone to RX-V663 but there is no output in speakers? Do I have to make changes to amplifier or select out some outputs?
How did you 'connect' the cordless microphone to the RX-V663? You will need to select this same input in order to get output in the speakers.
Sep 25, 2014 | Yamaha Rx V663 7.2 Channel 665 Watt...
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Feb 04, 2010 | Yamaha RX-V663 Receiver
Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Hope this helps. If you still have a problem, post a comment and I will help you further.
Dec 26, 2009 | Yamaha RX-V663 Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
I am onlty showing two channel speakers
Hello..if you have the manual for setting up you need to go to page 32 and use the auto set up to check out the system ..in this area it will test the speakers and even adjust the equalizer with the supplied osd microphone.. it will give various audio signals to all the speakers and even warn if a speaker is out of phase. After that test follow up carefully the other pages under speaker assignments. I hope that helps .
Mar 21, 2009 | Yamaha RX-V663 Receiver
Decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Mar 16, 2009 | Yamaha RX-V663 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
76 people viewed this question
 Grubhead
Grubhead
