Question about Acer Aspire 9300-5349 Notebook
How to install memory on acer aspire 5349-2592
How to open up computer to upgrade Ram
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Posted on Oct 13, 2007
Roynice152
  • 88 Answers
SOURCE: Installing Acer 5315 series memory
Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
Posted on Jan 09, 2009
jell587
  • 447 Answers
SOURCE: after upgrading RAM 1G to 1.5G
You should be good to go, if you had the wrong memory mod the machine would probably just blink or beep at you. If you experience blue screen errors or virtual memory errors this could be a sign of incompatibility but I would say you're probably fine.
Posted on Feb 26, 2009
gymowner
  • 679 Answers
SOURCE: Ram upgaded 1G to 1.5G
Hit start, control panel, system, device manager, and look under 'General" on the main screen, it should say right there the processor and ram type and size. If its not listed click on the hardware tab, go down to the memory, and click on memory/ram, it will be listed there. If it isn't showing or showing is showing he wrong speed, then go into the bios, by rebooting and selecting the delete key. If it shows under the memory speed, that it is the wrong speed, just click on that entry using the arrows esc, and enter keys to navigate the bios program. Highlight it and hit enter, select the proper speed ,hit f 10, and enter to get out of the bios menu. That should set the proper speed if it wasn't correct, good luck, you already did the hard part.
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Adding memory to Acer Aspire 4720z
The RAM memory slot is up on battery .
First open cover above battery plate then fix RAM there .
Jul 13, 2009 | Acer Aspire 4720 Notebook
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
How to install hard disk and memory of my laptop?
there are 2 door on the back of your laptop (Aspire 5580).
1 is for harddrive, and the other one is for memory+wireless cards.
just open the screw + the cover and you can see the hdd and memory.
Sep 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire E380 memory
Hi pimp69,
You can only use components compatible with Aspire series computers. Before you choose new components, please ask your authorized Acer dealer whether the part will operate within your Aspire series system. This is noted in your manual pg. 6.
Compatible memory for your Acer. Don't forget your Acer uses an intergrated graphics card that uses your system memory to function.
http://www.google.com/products?hl=en&q=Acer+Aspire+E380+memory&um=1&ie=UTF-8
Good Luck & Kind Regards.
Mar 19, 2008 | Computers & Internet
Help Access and Insall RAM to Acer Asspire 7720 Laptop
no its not easy to access original one but you can add addition RAM to your lap.
on bottom of your lap you can find screws for a small rectangle area. just open it and there is the place where you can put additional RAM
thanks
iqbal
Mar 11, 2008 | Acer Aspire 7720 Notebook
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire 9300-5349 Notebook Logo
466 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
