Question about HP Computers & Internet
Running Windows vista, I want to install HP wireless printing upgrade kit what driver do i need
  • ajmjetman Oct 28, 2008
    Thank you, you make it so easy for an old wrinklie like me.
    Scholar:
  • 35 Answers
You can Get the Driver on this link :
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3200077
** You can choose from 2 options :
1. Driver if you computer was upgraded from XP to Vista
2. Driver if you have Windows Vista Preinstalled on the system when you bought it.
** You also have a patch on the same page for issues for frequent USB Disconnects.
Posted on Oct 28, 2008
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Problem with HP Pavilion dv6767tx notebook (intel core2duo T5550 @ 1.83 GHz, 3 GB RAM, 250GB HDD) I Needed Drivers For WINDOWS 7. It had windows vista prior. Now i have installed windows 7 ultimate , 32...
there is alot of drivers contained in a PC i find it hard to believe that windows 7 cant find 1 driver for the entire PC any particular 1 you are missing? you may be able to install drive in compatibly to mode
your also not really stating your problem other than driver issue
I also see that HP does not have windows 7 support for this laptop
I have also read of people upgrading from vista to 7 successfully
maybe try upgrade instead of new install
Feb 05, 2011 | HP Pavilion dv6000z Notebook
Hp c6180 will not print from windows vista; no error message displayed on computer or printer; print queue says error printing with no explanation wireless installation hp solution center says no hp...
This means that your system does not display any printer name under the printer's list even though you would have installed your wireless printer on your Windows Vista system. This could be caused if you have not updated printer drivers in your system or the printer is incompatible with Windows Vista. Also see if the Windows firewall is blocking the printer from being recognized by your system. get more information for HP Wireless Printer Problems . Hope this helps you.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
I have a HP Pavilion tx2620es with Windows Vista 32bits working perfectly, i buy Windows7 Upgrade Kit from HP, so i installed it and all sort of problems became: -Rotation of screen has stop working -Touch...
TRY TO DO CUSTOM/CLEAN INSTALL OF WINDOWS 7, BUT BEFORE INSTALLING IT DOWNLOAD WINDOWS 7 upgrade advisor , HERE IS THE LINK http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en RUN IT ON VISTA TO MAKE SURE WINDOWS 7 IS ABLE TO BE INSTALLED ON YOUR PC. BECAUSE WINDOWS 7 IS NEW OS IT MIGHT GIVE YOU MORE TROUBLES ON TABLET PC`s, MICROSOFT STILL UPDATING THEIR DATABASE FOR CORRECT DRIVERS FOR WINDOWS 7, ANYWAYS , I`LL SUGGEST YOU RUNING UPGRADE ADVISOR ON VISTA.
Mar 09, 2010 | HP Pavilion Tablet Notebook
Hp v9410us wireless adapter card not working. Have windows 7.
If you upgraded to Windows 7 from Vista or XP, you will need to install the wireless card driver from HP for Win-7.
At present, HP does not have Win-7 drivers for this machine.
Jan 07, 2010 | HP Computers & Internet
When I try and connect the HP wireless upgrade printing kit it doesn't recognise the adapter and so won't procede. Any ideas?
you do not need an upgrade kit.....this printer is a wireless printer.....so can use it wirelessly without any upgrade kits.....just need to run the wireless setup wi\zard on the printer from the front panel menus and then nyou have to install the s/w using the disc that came along with the printer and you need to select the connctivity as wireless and then follow the on screen instructions...
Mar 27, 2009 | HP Photosmart C7280 Printer
Print driver for my HP Desktop 3920 using windows vista
You can download it here :
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=445442&lang=en
Dec 04, 2008 | Office Equipment & Supplies
Can't connect wirless to the printer I
Hi Judi,
I'm not sure but if I remember correctly the Hp F380 is a 3 in 1. I have used similar models. But did you install something like this
Miscellaneous Accessories s.gif s.gif q6259a_70x100.jpg HP Wireless Printing Upgrade Kit Q6259A s.gif Product name HP Wireless Printing Upgrade Kit s.gif Compatibility: View complete compatibility list
Apr 06, 2008 | HP DeskJet F380 All-In-One Printer
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
Computers & Internet Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
