Question about SanDisk Sansa MP3 Player
2GB SANSA Express
I have a Scandisk sansa express 2GB MP3 player.
Initially it was working fine. After few days its stopped working.
When i connect my MP3 player to the laptop (VISTA OS) i can able to detect the device and am able to see the files in that.
After unplugged if i start the player it is not getting started.
I have contacted technical support scandisk they have suggested driver updates but still am not able to start my MP3 player.
Can any one suggest is there any problem with this version player?
What is the resolving steps to correct my player.
I will be very much thankful to you, if you can give me some solutions.
Thanks & Regards
  • ugnfredy Nov 04, 2008
    i too have the same sansa express player and its not turning on when i press the menu button it shows sandisk on the screen and then nothing is displayed . and i cant able to view files in it it s showin as empty disk
  • isaacbassaw2 Mar 17, 2009
    the radio side of my sansadisk is not working when i turn on th radio it just freeze up the player and turns off.
  • 728 Answers
You may need to get either a memory stick to go in the available spot, or if you do not already have one and do not want to spend any money, get a paper clip and carefully stick it in the slot and it should come automatically.
Posted on Oct 29, 2008
  • Jazz Boyce
    Jazz Boyce Feb 11, 2009
    Here it is clearly:
    First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Press vol+ , Select & Menu buttons to reset your player. This will work fine. check it out
Posted on Nov 02, 2008
Dear Jazzyboy11,
I am not able to understand your resolutions steps. can you please explain me clearly.
Thanks & Regards
Shaik
Posted on Oct 30, 2008
My sansa express dosnt know it has a micro sd card full of music in it. please reply to: benharris185@msn.com
Early versions of the Sansa express will not support High Density microSDHD cards whcih are usually found in Cards greater than 2GB and definetely on cards greater than 4GB.
In Flash drive mode, make sure that the microSD card can be seen on your PC as a second drive for your Player. To ensure better compatibilty, I would suggest that the microSD card be FORMATted while inserted in your Player.
I would initially only put a couple of songs on your microSD card to test that the card is compatible.
Dec 22, 2009 | SanDisk Sansa MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
My computer recognize sansa express but drive does not open
Just to be sure, try both of these: First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Feb 26, 2009 | SanDisk Sansa MP3 Player
Need driver
There was no driver software on the enclosed cd.I downloaded the software thru a google search.That put my sansa mp3 in good working order.Thanks .
Salscimemi
Jan 22, 2009 | SanDisk Sansa m240 MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Help me
I have a connected message when was disconected from the computer. I tried to shut it down but does not work.
Jul 31, 2008 | SanDisk Sansa MP3 Player
SANSA EXPRESS
Not sure but it could be dead, but dont worry till you do a hard reset by pressing and holding down the "select(Square button)"and "volume up" buttons.
I just got mine today and been looking through the sandisk forum.
Hope that helps bye :)
Jun 15, 2008 | SanDisk Sansa MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Jun 09, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa MP3 Player Logo
263 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
