Question about AT&T Cell Phones
I have tooken the battery out for 10 minutes like this thing has said and its still not charging nor turning on? What else do I need to do???
  • Seana Feb 24, 2012
    What kind of phone is it
  • 3 Answers
Sometimes you just need a new battery. If you took the battery out and gently put the battery back in and it still won't turn on. Take it to the store you bought it and get them to look at it.
Kris R.
Posted on Feb 24, 2012
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
Jul 20, 2014 | Dyson DC16 Root 6 Bagless Handheld...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Shuts Down (6930p)
this is can happen with any laptop battery, when you leave it on charge the cells in the battery die and cannot retain their charge, so the battery will say 100% 4 hours remaining but it really only has 10 minutes.
the only thing you can do is buy a new battery
Dec 24, 2013 | HP EliteBook Computers & Internet
It has been charging for 5 hours like this and doesn't turn on. What do I do? It turned on twice but stayed at 1% for about 10 minutes but then shut off again. I have no idea why it is doing this and
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 11, 2013 | Cell Phones
My sansa mp3 only begins to turn on when i connect it to the pc but then freezes when it says 'Sansa m250 2.0 Gb' please help
Look further than the batteries. Take the whole thing apart. That's what I do, and I've fixed a lot of things. And keep looking on the internet. A few hours of looking can result in years of listening.
Jun 16, 2012 | SanDisk Sansa m230 MP3 Player
My battery was left on for 15 minutes now when i turn over key , I have fyll power but engine will not start . Only lots of clicking sounds almost as if it is the starter even though I know it is not.
here is what you need to do you need two wires , one another car , just plug the terminalsof the battery of another car + with + of your car battery , and nagative with nagative, do not interchange the terminals or your blow up the battery .
now note that the other car should be in start state. i mean the ignition should be started and should be in neutral.
may be this picture helps you
then stry to start your own car ... if it starts make it start for 10 to 15 minutes .or drive free for 10-15 minutes t charge your battery
but before this whole thing are u using dry or wet battery if you are using wet battery then check if its not empty pour simple water in it and fill all the knobs .
i hope it helps
Apr 04, 2011 | 2006 Chevrolet Cobalt
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
I have a go kart with a 1979 250cc kawasaki enduro motor in it, and there is something that got tooken off and its what make it so the battery keepts charged, just wondering if you know what that its and...
To keep a battery charged you require several things, source coils and magneto (on end of crankshaft) leads from which should go to a rectifier/regulator, ignition coil and the cdi unit or black box. Leads from the black box and magneto should trace back thru' a fuse to a battery if a battery is required. However, Enduro lighting and ignition systems were developed without batteries in mind mostly.
Apr 20, 2010 | 2007 Maico 250 Enduro
Cell Phones Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
