Question about Frigidaire 15,100 BTU Heavy Duty Window Air Conditioner
On the pad the only thing that shows is A5.....it runs and cools great....just cant change the temp
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
Tip
When should you change the grease on your Oster A5 or 76 clipper
Oster A5 or 76 clipper need to be grease at lease every 4 month so they can run quiet and cool. when changing and removing the grease, You need to remove the old grease completely, or You are doing more harm than good. By doing this on a routine base, You are saving wear and tear on your gear,lever,link and blades. and the clipper motor will run cooler.
on Mar 30, 2010 | Kitchen Appliances - Others
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
GE Profile Refrigerator PSS26SGPSS stopped cooling on both fridge and freezer side. Temp controls show current temp (now 78), but when I set for lower temp, nothing happens. Hear small fan running, but...
heatman101
Apr 01, 2011 | Refrigerators
The temp. control dial doesn't change the temp. and the fridge is just cool and the freezer is thawing. What to do?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 29, 2011 | Maytag MSD2756G Side by Side Refrigerator
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Oct 26, 2009 | Polar A5 Wrist Watch
1999 Sable quits shifting when it gets hot
How do you know it's getting hot ? What is the Temp gauge showing ? Do the cooling fans work ? Have it checked for trouble codes an scan data checked .
It was however the correct thing to do in changing the fluid and filter - that's the first suspect. No no it wasn't , the correct thing would be to take it to a qualified repair shop . Hooking up a professional type scan tool an viewing data , inputs to transmission control module , ECM/PCM - engine computer etc. The control module controls shift solenoids -which shift the transmission . You could have 1-2 shift solenoid shorting when getting hot . View scan data is the only way to see this problem .
Jul 22, 2017 | 1999 Mercury Sable
95 grand am radiator fan only runs with AC on
Cooling Fan Temp Sensor is the First thing You Check (with what you have described) Cooling Fan Should ALways come On When The A/C is turned On as A/C Adds A Load to Engine, If Temp Sensor is Faulty it Will Not Give GROUND Signal to ECM >For COOLING FAN >RELAY to Give ground and turn ON The Fan.
There ARE 2 temp Sensors that Serve Different Purposes 1 is for Dash READING GAGE & Or TEMP LIGHT the Other is For ECM or Fan Relay (SAME Thing) you Said>""can disconnect the sensor and fan continues to run" < This Leads me to think you Changed the Wrong One. Not Questioning your Skills Just Here to Help.
TEMP SENSOR FOR 3.1L V6 is Located upper RH rear of engine compartment, near exhaust system. Temp SENSOR for 2.3L Engine is Located in LH rear of engine compartment.
I Hope this Helps Lead you to a NON-OVERHEATING Pontiac.
Good Luck and Have A Great Evening. rejakwilson
Feb 04, 2009 | 1995 Pontiac Grand Am
Frigidaire 15,100 BTU Heavy Duty Window Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
