Question about LG Cell Phones
I have a lg optimous. What does it mean when it keeps say yor sd card has unexpectedly been removed. It does this like 5 times a day.
  • 380 Answers
What i did to fix it was i took out my battery fr a few minutes then put it back in and turned it on and didnt touch any of the buttons for a few minutes and it stopped doing that hope it helps (: Was this answer helpful
it's either an issue with a batch of SD cards that shipped with the phones (in which case user a different SD card) or it's an issue with the formatting of the SD card as shipped (in which case, reformat the existing SD card)
Posted on Feb 24, 2012
5 Suggested Answers
SOURCE: I cannot remove my sd card from my lg dare. How do
To insert the SD Card you had to push it in the SD Card slot until it stayed in the phone. To remove the SD Card simply push the SD Card into the phone and it will eject itself. I think it is spring loaded or something. It's almost impossible to remove the SD Card by pulling on it.
Posted on Apr 10, 2009
kikofix
  • 24 Answers
SOURCE: lg klp500 restarts when opening gallery with sd card inserted
Try to format the memory card first with the computer
Try another card
Look for the supported card for the phone
basically that means that the phone cannot really read the memory card or the card has a broken or corrupted file
Posted on Sep 25, 2009
jayatithapa
  • 83 Answers
SOURCE: i insert new SD card
sd card slot damaged. Change slot with new
Posted on Mar 16, 2011
  • 34 Answers
SOURCE: Red triangle icon appears saying
For this problem contact your mobile service provider.
Posted on Sep 06, 2011
How do I get my files off of an sd card(for a phone) that neither a phone or computer can detect?
hi this might help, ime not sure but try it, take card out of phone and put it in sd slot on your computer if it has one, if it dose not read the card, then go into windows explorer then computer and see if it is there, if it is then right click on it then press properties this will tell you if the card has anything on it, if it has then press it to bring up the info on the card, pictures and music and all data, hope this helps you...
Dec 18, 2014 | SanDisk 16gb Micro Sd Hc Microsd Memory...
Huawei Ascend II hung and I had to remove the battery. When restarted after putting battery back in, it got to "preparing SD card" and an error then appeared that said com.android.huawei.keypadprogramming...
If you have an SD card in the cell phone, remove and restart the phone. If that doesn't work, do a complete reset. Keep in mind that you will lose all the data in your phone when you do that. Please take a backup before resetting your phone.
Sep 13, 2017 | Huawei Ascend Ii
My Kyocera Rise has LOTS of problems! The one I want to ask is why do I keep getting a random message saying, "SD card has been unexpectedly removed"?
There are several possible reasons for this. The Kyocera Rise requires an SD card to be unmounted through the memory option in the settings. If you remove the SD without unmounting, you will receive the error message. The Rise also has several software issues that sometimes cause your SD to stop being read, even while still inserted. If you receive this error message without removing your SD card, it is recommended that you take your phone to a company certified Sprint store to have it checked out.
Jul 01, 2013 | Cell Phones
I have problem with camera saying not working!!!
If it's been a week, you may just want to try to factory reset. If that doesn't work, take it back to the carrier and explain what's going on. You have a 30 day warranty when you buy a new phone.
Feb 17, 2013 | LG Cell Phones
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
Can't get my lg optimus to sync with pc keeps asking for disk didn't get one
on your phone,go onto settings...go onto sd card and phone storage...check the box(make sure it has a green check) next to mass storage only...then it will say tuen on usb storage and tap the box that says turn on usb storage..that should do it when you go onto the my computer setting on your pc you should see removable disc E or F click onto it and you can transfer things from yor computer onto it or things from it onto your computer...
Dec 26, 2010 | LG Cell Phones
My LG VU CU920 keeps turning off
I had the same problem even after I exchanged the phone for a new one. The problem seems to be related to Mobile TV and the SD memory. When I removed my 2GB SD memory, the problem has not reoccurred. I recently installed a 512MB SD memory chip and so far I have not experienced the problem.
Jan 02, 2009 | LG Vu CU920 Cellular Phone
Cell Phones Logo
61 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
