Question about Zebra LP 2844 Thermal Printer
Only every fourth label Prints
I have a Zebra LP2844 label printer onto which I am trying to print barcodes. I have managed to get the barcodes to print, but only on every fourth label. Any suggestions would be most welcome.
We've been having problems with ours. Make sure that the properties are correctly set, landscape, portrait, 180' rotation, label size, on the printer properties. Then check again through whatever package you are using 'printer properties' and try a print. You may have to re-enter properties each time you print.
Posted on Jan 22, 2007
Hello I was working on Zebra LP2844 label printers. I need to print labels and barcodes from a data source using EPL.I have never done this things before so any help is appriciated
Epson standard code is totally different. EPL is Eltron printer language. I've not programmed in it, but there should be a programmers manual out there somewhere.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Cannot print multiple copies
Is the printer set for label taken, if it is then it is waiting for the sensor to see the label is gone before printing the next one. Apart from that, check the settings in the driver and make sure it is all set correctly
Feb 09, 2010 | Zebra Z4Mplus Label Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP 2844 Thermal Printer Logo
217 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
