Question about Fisher and Paykel Kitchen Ranges
My dcs range burners flame is very uneven . How can i fix this?
Illeagle
  • 525 Answers
SOURCE: The burners in the gas
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Yellow flame and black soot is an indicator that the flame tube is being starved for oxygen. Where the orifice injects the fuel at the base of the flame tube you should find a movable air adjustment shutter that is usually held in position by 1 screw. This screw may have loosened and allowed the shutter to close off oxygen to the flame. Below is a link to a page that shows an oven burner tube...click to enlarge image pn1015233 and observe bottom end. Rotate shutter any direction until a nice blue flame appears but is not "blowing" off the burner tube. Tighten screw to retain position.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1015233&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
  • 1462 Answers
SOURCE: igniter will not shut off on my DCS RGS-366 gas range
spark generator is faulty usually - replace
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Posted on Oct 29, 2008
trav1856
  • 57 Answers
SOURCE: flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Posted on Dec 06, 2008
Kgt1962
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
Why is cooktop burner flame uneven?
Check for clogged burner orifices.
Mar 22, 2016 | Frigidaire Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Large burner has uneven and too strong a flame
could be the burner cap. possibly not converted proper. or burner assy bad
Apr 22, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Side burner on Jennaire grill
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Kitchen Ranges Logo
110 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
linnap
Bob Kirkwood
J D Wright
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
