Question about Sony DCR-TRV-428E Hi8 Easy Handycam Pal System Camcorder
Sony TRV 428E Pal
1-When you attarch the power cable,the camcorder is not charging the battery but the L C D Screen comes On..(orenge light is not coming on.)
2-The L C D screen is constantly On with white bright screen insted of blue screen for the playback or view images for the capturing mode.
3-The cassete stuck inside hence refusing to come out even when you open the door and the power is on.
4-The On/Off switch has no effect,its as if the camcorder
failed on an On mode.Plz assist.
Moses Mwachia- Africa(Kenya)
  • 188 Answers
SOURCE: camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Posted on Sep 15, 2006
philipp
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
SOURCE: Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
its because sony is recall for Sony Digital camcorder TRV22
Posted on Oct 20, 2007
  • 497 Answers
SOURCE: i have a sony dcr-trv 22e camcorder and i am not
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer using i.LINK cable.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
SOURCE: Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Posted on Jan 26, 2010
SONY DCR200 CAMCORDER turn off when I Opend th LCD but it's working when attached with AC power Cable
More than likely the camera has an internal problem in the power supply section. There is an electronic switching circuit that switches between the battery input and the DC input coming from the AC adapter. Your camera requires professional servicing. One such place is AVRepair.com Home Services Consumer Camcorder Sony
Nov 25, 2014 | Sony Video Cameras
Not Charging problem
Your battery is dead. Batteries only have a useful life and have to be replaced. Your power cord is ok because you are allowed to be on the computer with it plugged in. But the power cord cannot charge a dead battery that is beyond it's useful life. Replace the battery.
May 25, 2012 | Computers & Internet
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
I am charging my new Flip Ultra HD battery pak for the first time. The charging light is flashing, non-stop. I thought the light was supposed to NOT flash while charging. Also, should the camera...
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
Jul 22, 2009 | Pure Digital Flip Video Ultra Camcorder
Charging the battery on Jazz HDV178 digital camcorder
WHAT KIND OF CABLE DO YOUUSE TO CHARGE A JAZZ HDV178 I WENT AND BOUGHT ONE BUT IT DON'T CHARGE THE BATTERY ?
Dec 31, 2008 | Video Cameras
JVC Camcorder - used wrong power lead to charge battery
There is a circuite protector near by the connector which is coming from the battery to mainboard.Just replace the same.
Nov 15, 2007 | JVC GR-D20EK Camcorder
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Dec 19, 2006 | RCA PROV712 Camcorder
Sony DCR-TRV-428E Hi8 Easy Handycam Pal System Camcorder Logo
51 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
