Question about Sony Handycam HDR-UX7 Camcorder
Error C:13:02 - Can't recognize any disks
About 6 months into having this camcorder, I started to get the error C:13:02 (disk may be scratched). I tried MANY different types of disks. Eventually, the problem increased to the point where it happens 100% of the time. Every disk I put in there gives me this error.
  • sprouty11 Jan 17, 2009
    I have had this problem twice now with the same Error C:13:02 with my Sony DCR-DVD92. The first time it resolved itself and I don't know how. This time, though, I have cleaned the disk and tried again. And, once since, I have successfully recorded and finalized a disc.
    Not sure what to do to get the error disk finalized????
  • arishkamal May 13, 2009
    I'm using SONY Handy cam, while start shoot the video Error C:13:02 coming please give me solution.
    Kamal
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Drgadgt
Posted on Nov 15, 2008
Use this program to recover any unfinalized disks http://dl.dropbox.com/u/13959066/IsoB.zip ; then replace your dvd camcorder for a mini dv camcorder. DVD Camcorders are the worst invent ever!!!
Posted on Jun 09, 2011
I have problem too
Posted on Jun 27, 2012
Nero 7 Essentials.... I happened to find that is came with my Dell bundle software package but it was never actually installed on my PC. So I lucked out on having to purchase it.
Open Nero once installed -> Select "Make DVD, DVD-Video"
Select on the right -> "Import Disk" (insert your **** disk at this time)
#This step will import all of the on the disk that it finds and change the VOB files to .mpg files.
Click on "Save your project" periodically, now is a good time.
Now you should have a list of clips from your DVD. If you double click on the title area you can update the titles as you wish.
-Save again? -->Next, Review, Next,
You should now be at the point where you can burn to DVD or save to your hard drive.
Tip: Note when you imported the files and where they went to. You can make a copy of a .VOB clip if you are looking for just a clip of the video. Change the extension from .VOB to MPEG, save like this and then you should be able to open this file for viewing.
Posted on Nov 15, 2011
  • 3 Answers
You must have the cameras power supply connected when finalizing.try tested works.
Posted on Apr 20, 2010
What does error code 2881 mean?
Error 281 is a disk recognition error, bad disk, scratch on disk or disk contains moisture (dry it)
Try
1.- get out and reload the disk
2.- Clean the disk for Dust / scratch
3.- clean pick up lens (with a soft clooth or a piece cotton
4.- Replace the disk and check if the error message continue.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Hitachi DZ-MV230A DVD Camcorder
Hi - When I insert a gaming or music disk into my PS3 it makes a noise as if it wants to eject the disk again. This either happens or otherwise it wont recognize that a disk has been inserted. This...
Hello, It's possibly lens calibration problem, sometimes that happens when there's a lot of sudden movements during transportation, sometimes the use of scratched disks tend to trigger the Error correction algorithm of the PS3 reader, putting the reading lens into a lot of stress that heats up the EC chip and games are not read properly, causing the game to fail loading and making unusual sounds.
I recommend not to use scratched disks, try to use only PS3 game disks only to extend your console's life, and take good care of all your disks, keep them clean.
The thing is as technology improves Disks format changes to put more information into a single disk, and precision looking for data is more critical as data sectors are closer to each other, so scratched or dirty media tends to return errors.
Hope I helped, and try to seek some professional help on calibrating/substituting your old reader.
Apr 28, 2011 | Computers & Internet
I have tried to play 2 dvd's from netflix. I have used this player for 6 months and not had a proble. Both dvd's didnt play and disk error message appaered
Double check that you don't have BluRay disks that you are trying to play in a standard DVD. Or that they are upside down...
Netflix disks, in my experience, have all had scratches and gouges on them. It might be that you are the recipient of 2 disks in a row from netflix that are too damaged for your DVD to play.
Jun 11, 2010 | Televison & Video
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
My pioneer car audio player supports mp3, wav, but recently started showing error 11
would need the model number of pioneer. But generally this error on most pioneer refers to a dirty disk, scratched disk or dirt on the lens inside the player. try using lens cleaner and clean all your disks. Car scratch remover such as t-cut is good for removing scratches off disks.
Jan 26, 2009 | Pioneer DV-300-K Player
Not good. It sound as though it will need the disc mechanism unit replaced.
Dec 29, 2008 | Sony Handycam DCR-DVD201E DVD Camcorder
Disk Error
If the camcorder does not read any disk, and makes noise when reading a disk and does not start reading, then the problem concerns either motor assembly or lens pickup.
If the disk is spinning and lens had been cleaned already, then the lens must be replaced.
Oct 16, 2008 | Canon DC20 DVD Camcorder
Finalising
i bought a camcorder from currys model vp dc 172w back in october. i took it to las vegas to record my wedding. its recording fine but i cant finalize the disks. iam folowing the instructions from the book. on 1 disk its trying for about 30 seconds then is saying disk error. the other disks i cant even get them to start running. can you help me please.
Oct 30, 2007 | Samsung VP-DC161 DVD Camcorder
Sony Handycam  HDR-UX7 Camcorder Logo
7,117 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
