Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 No printing
I have a problem with All in one Lexmark X5150...it prints white pages...I have checked for ink level, i tried with a new cartridge, I read the trobleshooting from X5150 but I still could not figure out whats wrong. The plastic foil is off, the printer is on ready status and is set as default, the ink level is ok, the paper is ok, the connections to USB are ok, but still doesnt print. I restarted the PC and the printer, but still nothing...I really dont know what else to try...
  • Anonymous Nov 16, 2008
    I ran the black ink cartridge completely out. When I put in a new one, neither the black nor color works. I get a blank page.
  • 21 Answers
Uninstall the printe driver,then try reinstalling the printer back.if no luck,change the usb cable or printer cable as the case may be,if doesn't work,try using the printer on a friends machine. did it work?let me know. eyo7 eyoifiok2005@yahoo.com
Posted on Mar 05, 2007
Printer lexmark x5150 not print
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Nov 11, 2011 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
Color won't print.
Make sure you removed the plastic tape from the cartridge.
Make sure color is enabled in printer properties on the computer.
If this helps please vote for my solution.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Not printing
Here are the best instructions on how to clean the print cartridges.
Feb 25, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Nov 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
All in one printer fault
Pull the cartridge check to make sure you removed the seal. Take a damp cloth gently wipe across the ink openings. If you get ink reinstall. Go to printer settings and make sure you are not set on documents black and white but on colour printing. Go to maintainance run test page several times. hope this works for you.
Sep 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150
hmmm..ok..so when you attempt to do the clean and calibrate, what exactly is the condition of the printer?
Jun 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 printer (serial #10450991811): Error message reads "color cartridge missing." It is not. With the last cartridge, printing was light and scattered; could not print anything...
Went to online chat with Lexmark. FREE.
They offered to replace cartridges as they felt the ink was dried out in one, and the ink jets in the other were damaged.
Apr 18, 2008 | Lexmark Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
