Question about Dryers
Assembly rear bearing drum fisher and paykel ed56
4 Suggested Answers
  • 1028 Answers
SOURCE: How to replace the bearing
top load dryer?? open top right end of drum remove toex screw and cover brass bearing slides out.. front load pry up top srews top inside front lift front out remove belt lift drum out bearing in back on rear wall
Posted on Apr 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: I want to replace the
Now you need to get your hands on the replacement part for your dryer, you will need to find an authorized F&P servicer to sell you the part (part #479332 btw) or call Fisher & Paykel directly to get the part from them.
OK below at bottom, is a user manual, below, is an exploded parts manual, this should help
www.stokesap.com.au/...DRYERS/517708%20All%20Dryers%2025-03-
www.fisherpaykel.com.au/admin/.../427621B_Dryer_UC_UD.pdf
http://www.hamiltonnorthappliancerepairs.co.nz/parts/dryers.php
Above is a place to get the bearing kit.
Posted on May 06, 2011
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
How do i remove the front of ed56 dryer
its done by going through the back by removing the drum and belt
May 06, 2014 | Fisher and Paykel Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
My F&P ED56 dryer just hums when it is turned on. The lights come on and it hums, but it doesn't turn or blow air. We have checked the belt (that is OK), the drum can spin by hand, there is no lint...
sounds like it maybe the motor, here are other reasons the drum won't turn and how to open the dryer. Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 28, 2010 | Fisher and Paykel Dryers
Model 708 has a high speed bearing noise during rinse cycle Can bearings be replaced?
Hello,Here is how to tell if it is the rear bearing. Open the door, grab the inner drum and see if you can move it while not moving the outer tub. If you can, then the rear bearing is bad. Fridgidaire doesn't sell the rear bearing by itself, they sell the rear outer tub shell, also when this happens the shaft on the inner drum is worn and has to be replaced. I have seen this repair cost as much as 600 dollars USF to do this repair. What causes this is using too much or high sudsing detergent. The rear seal is a water seal, however suds will wick pass the seal like a light grade oil. Also water will not remove the grease from the rear bearings, however detergent is designed to do just that. You may try calling Fridgidaire and see if they will at least provide the parts at No Charge.
Thanks
May 22, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Mar 06, 2010 | Fisher and Paykel Dryers
AD55 Dryer makes a dual clunk like it is out of round.
Run the dryer and look through the front door and watch for if the drum is running out of round at the back. The AD55 only has one bearing and this is at the rear of the drum, the front of the drum is supported by 6 plastic tabs that it glides over. These tabs are reversible if they become worn and a drum bearing assembly kit is available from Fisher & Paykel. For a detailed drawing of the dryer contact your Fisher & Paykel service center and they will email you a copy.
Mar 02, 2010 | Fisher and Paykel Dryers
Fisher and Paykel Dryer ED56 Noise
your rear bearubg is mnost likely failed. and the back plaer is now hitting against the drum.
Part number (Fisher & Paykel Dryer Rear Drum Bearing Kit Part 479317)
you can replace this eazily by yourself.
check that the belt is over both rollers as well.. sometimes they slip off one of them.. especailly if moved around.
but this rear bearing is very bad. If you can find a skateboard bearing. it will fit nicely too. a much cheaper replacement and works fine. must get a good quility one lol (but any flate bearing is fine if you can find some in your workshop or neighbours lol
Jun 03, 2008 | Dryers
How to replace the bearing on the drum of a fisher&paykel dryer ED56
Apr 24, 2008 | Dryers
Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Mar 18, 2008 | Fisher and Paykel Dryers
Dryers Logo
263 people viewed this question
Top Dryers Experts
