Question about Home
We don't know how to operate the maax hydromax-aeromax hottub in house we recently bought
Control panel on side and occas blnks please help
3 Suggested Answers
  • 10 Answers
SOURCE: I don't know how to work my Maax hydromax double
Try to downlaod the manual from the maax website. Hopefully you can find the model #. Look around in the pump acess area for it. If you cant find it try to match it up with a current model image from the website or do an online image search. All major companies offer there liteture available online somewhere, maybe under a seperate tab, on the product page.
If this does't help you should post again and be more specific i.e. what can't you get to work? Tubs these days have many different feaatures. Also model # and estimate what year it may be.
Wish I could have been of more help.
Sincerely, T. Wood C&F Enterprises a plumbing contractor.
Posted on Oct 08, 2009
tunde007
  • 2382 Answers
SOURCE: Maax bathtub (I believe Saturna)
Hi, the from your explanation it's quite obvious that the controller is faulty and needs to be replaced. You can try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada.
Posted on Mar 01, 2011
Control Panel
Most topside panels are just stuck on the top of the tub with a double sided tape.
Sometimes it can be held into place with a nut on the underside that must be unthreaded to remove the top panel.
Rod
US Parts Center
888-521-6183
Mar 29, 2014 | Maax Living 7242 Hydromax Whirlpool -...
Maax hydromax whirlpool
wire an extra thermostat to it..have it control the heat
Jan 08, 2014 | Maax Home
The proper way to reset the controls on hydromax aeromax maax
Turn the circuit breaker off for about 2 mins then turn it back on.
Rod
US Parts Center
888-521-6183
Apr 07, 2013 | Home
I have a maax hydromax tub and the temp. control needs replaced where can i buy one
Not as easily done as you would expect. What is the Model number of the Control Box under the bathtub?
We need to know that before we can match up the sensor for you.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 | Maax Home
Where is the filter located on a maax whirlpool drop-in tub
As far as I know you do know have a filter. I have read my instruction manual and it does not mention a filter at all. I have the Topaz 6036. To clean it you are to fill your tub with water and put in dishwasher detergent and let the tub run for a few minutes. You can also add a small amount of bleach.
Dec 17, 2011 | MAAX PALACE 6-JET HYDROMAX DROP-IN BATHTUB...
What does CO1 error mean on my Maax whirlpool
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on, if that doesn't fix your problem, then remove the access panel to the mechanical space in your tub and there are one or two reset buttons in there which can trip and need to be reset.
May 29, 2011 | Maax Calla 7242 Hydromax Whirlpool -...
I have a MAAX Hydromax - not sure about the model #. The blower and circulation pump no longer engage. At first the problem was intermittent now it will not work at all. I tried to trouble shoot the...
yes. search US Parts Center for a solution. They will want to know the model number of your pump and model number of the controls you have.
Most likely it is a bad circuit board in the control box that turns the pump/blower on/off.
Jan 25, 2011 | Home
I don't know how to work my Maax hydromax double tub. We just moved into our new house and the owner did not leave instructions. Please help
Oct 07, 2009 | Home
Home Logo
136 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
