Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HDLP P50W151
Originally had no picture, just sound, so I changed the bulb. Now I have menu, sound, but no picture. I can switch inputs, but get no video. Can any one help.
  • davehirst Oct 30, 2008
    Did try this. Have Satellite, Cable, DVD and VCR all connected. Ran a wire directly from Sat to TV. Still nothing. Have tried all of the above equipment, still only have menu screens, nothing else. There seems to be a light grey screen (Very light) when the menu is gone, but no other video. Thanks.
  • warhead30 Oct 30, 2008
    my tv has sound but the picture is off. it is 3D with the RED, GREEN and BLUE in different spots. the pitcure looks bent
    Genius:
  • 2,920 Answers
Have u put the tv on cable or on video for dvd? you might try switching those around
Posted on Oct 29, 2008
Rca 42'' plasma hdtv no picture but sound
Try to use all the possible inputs to see if they are all "out". The bad news is, unless you know how to switch within inputs withouts a sreen shwing you what are you doing, you are out of luck. Use the remote, perhaps. If still no image, bulb is out - perhaps get a new TV.
Oct 28, 2013 | Televison & Video
Rca tv has sound no picture
Check its line output transofrmer [LOT] and related components. Replace them
Apr 22, 2012 | RCA Televison & Video
Have panasonic pt l701u projector using RCA input can't get picture can get sound. Tried changing settings and it didn't help.
Pleeaes connect Rca cable in Yellow port for video and white port for audio.
Also check input settings in projector Menu. it should be "video".
For your ref, diagram is below
Thanks,
Mar 25, 2010 | Panasonic PT L701U Multimedia Projector
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Televison & Video
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
I HAVE A RCA HDTV SCENIEM AND IT DOES NOT HAVE A PICTURE OR SOUND TURN IT ON AND THE LIGHT LITES BUT THATS IT CAN YOU HELP
try changeing the input selector if you have a dvd player put it in turn it on and play it then run threw the menu also make sure you have not changed the channles it recives the signal on like 3 or 4
Jun 27, 2009 | RCA HD52W59 HDTV Projection Television
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Connecting component video YPbPr to TV with BNC port for RGBHV
No, this will not work. Picture will roll vertically. Originally they intended for HDTV to be red,green, blue, & Horizontal, Vertical sync. That changed after the first generation mitsubishi's.
In the service menu you can change the settings for the HDTV Input. Try that first by "Hitting menu button followed by 1259" or menu 1257. Let me know how that works for you, If you need a different code for service menu...contact me again and i will look it up for you. But the answer to your question is you can make it work or you can purchase a 300.00 box that will allow you to switch to that input thru..mitsubishi.tv.com
Good luck and keep me posted. GURU JAY
Dec 08, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
