Question about Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment
How do you rewind the recoil spring on a poulan pro trimmer?
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: how do you get the starter rope to rewind after
The starter rope normally rewinds automatically when the recoil unit is functioning properly. If the pull rope has stayed out, disassembly will be required. Here are instructions for that problem. The recoil spring can break and is replaceable, but the nylon hub in the starter recoil unit is usually the problem or the rope has broken and jammed inside.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Here are more details for servicing the starter/recoil unit....With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are doneervicing the recoil unitl
Posted on Jun 05, 2011
#1 Taper
  • 1041 Answers
SOURCE: poulan25cc 16 inch how do i rewind trimmer line on
You should wind it on the spool the opposite direction that it spins while operating it. If you wind it in the same direction as the spin, the line will come off the spool when in operation.
Jim
Posted on Jul 29, 2011
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
I have a poulan pro backpack blower (the 30cc one) and recently tried to start it and the rope extended all the way and won't recoil. i pulled it apart and can see the pulley inside the cover, but how do i...
The recoil spring might be broken or unhooked from the pulley. You would have to remove the pulley to find out what the problem is. But doing this, the spring could uncoil from the spring housing and it is dangerous that it could hit you in the face if you are not very careful. The spring is very difficult to rewind into the housing. I would bring it to a shop if I were you. Whatever you do, good luck.
Nov 22, 2010 | Garden
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
Gentlemen, I have a Mighty lite Trimmer of which the cord does not recoil. It appeares that the heavy torsion spring bends when cord is pulled and cord stays out instead of recoiling. Where can I get...
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Aug 17, 2010 | Homelite Mighty Lite Lawn Trimmer
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment Logo
139 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
