Question about Linksys Wireless-G WRT54G Router
Lost connection to internet after 2 days
I configure my router linksys wrt54G v2.2, with the last firmware, it works fine 1 or 2 days, but after that, I lost connection to internet when I connect whith my laptop.
When I use the setup page of the router, in diagnostics, I can make a ping test to internet without problems. but the laptop don`t have internet.
Any suggestions???
  • pepeviche Oct 29, 2008
    Ryd66, thanks for your response. But the wireless service is not only for 1 computer, and I don´t want to enter every mac address to the set up of the router, because the router is like a public access in the office.
    There is another solution???
    Ok, Thanks Ryd66 for your quickly response.
    Scholar:
  • 65 Answers
I ran into the same problem when i was living in Reno.
I fixed my problem by First, Access Command Prompt, by way of Run Program: CMD
then i inputed the command ipconfig /all
Find the wireless portion in the information that it gives you, what you are looking for is the Mac Address. it should be 12 total Alpha Numeric string, which is seperated every 2 by a dash marker.
Next, access the router through the normal way of browser, In the Wireless section, there is a tab that you select to input the Mac Address into the router, to basically give the router a permission to always give that computer access to the internet. This worked for me. I do hope it works for you. Its what i have always done in the past when i set up wireless Offices
Posted on Oct 29, 2008
  • Robert Ryding
    Robert Ryding Oct 29, 2008
    Ok, other than going through every computer and ensuring that when each connects to the wireless, they automatically Use Domain Name and Password, which is difficult at best. I cant really offer much. The mac address way is not the worlds most difficult way, its just the most odd way, because not many use it. I find it easier than everything else because of the fact that its a secuirty extra that ensures little tampering.
    http://www.wi-fiplanet.com/tutorials/art...
    http://technet.microsoft.com/en-us/libra...
    Here are two Information based sites that i go through when i need more detailed information about certain subjects. These pertain to your situation
I am having problems with my Linksys wireless router WRT54G connecting with the internet. When I connect the router to the internet I lose internet connections. Normally it works with the internet, but in...
1. RESET both the modem and router by unplugging them from the wall outlet for 30 seconds.
2. Power them ON again, and after 2 minutes check the connection.
3. If not OK, connect a computer directly to the modem, reset the modem and check the connection after 2 minutes.
4. If not OK, check your cables and if these are OK, call your ISP for your status and line quality.
5. IF OK, check the Powersupply of the router.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Internet will not connect, light is blinking on mode. It will work fine foe days and then be out for days.
your Linksys may need a firmware update. Also, can you make sure no appliances are near the Linksys? What happens right after you restart the Linksys? Works fine?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from http://www.linksys.com and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
I just got a Linksys Router and im having trouble connecting to the internet?
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 18, 2008 | Linksys Wireless-G WRT54G Router
Wrt54g V8 Suddenly stopped working
hello!
May 07, 2008 | Linksys Wireless-G WRT54G Router
Internet connectivity problem
try to upgrade the latest firmware for the router and reset and reconfig it..
Dec 27, 2007 | Linksys Wireless-G WRT54G Router
Wireless router disconnects every 5 minutes...
I had the same problem with my dlink (not wireless). Try going to their website and configure the router. It worked to me.
Dec 07, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
