Question about Bose Lifestyle 12 System
What is the impedance of the Bose Lifestyle 28System cube speaker arrays ?
4 Suggested Answers
SOURCE: Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Posted on May 17, 2008
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
gopakumarg43
  • 74383 Answers
SOURCE: What is the impedance of
Hello
The impedence of all speakers are [3.5 Ohms]. May connected upto [6Ohms] instead, provided the output will be a little less. Bass module cannot be connected with other sources. If you are intented to hear the music on an other room you can add speakers. For more detail, go to page [29] of its user manual, where all details and switching data are provided. All cannot be send by this window, as it will be out or capcity of this answer window. If you haven't its user manual with you now, send your email address to me by FixYa. I'll send a copy of it to you by return mail.OK.
Posted on Jun 02, 2011
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
What speakers can I use with a Bose Lifesyle 28 AV 18? I'm being told that there isn't anything other than the original factory speakers? This can't be right?
Bose work best with Bose speakers. It doesn't mean that you can't use other speakers, Just match the impedance (2 or 4 or 8 Ohm)
Sep 20, 2009 | Bose Lifestyle 12 System
Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Sep 11, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Jul 28, 2009 | Bose Lifestyle 38 System
Bose 'Double' Cube Speaker Came Apart
Carefully unsnap the speaker cover you may want to use a jewelers screwdriver or a small flat tip to assist with getting it off. Once its off unscrew the 4 screws completely and then carefully wiggle the speaker from he cube. Once the speaker is out of the way reach in the cube and reset the plastic coupling so its flush with the inside top of the cube. With both cubes on there sides and the rubber washer and swivel ring in place press the bottom cube, with your finger(s) inside the cube on the plastic couping, up into th top cube until you here or feel it snap into place. Once it snaps into place, adjust the insulation in the speaker then wiggle the speaker back into the cube and carefully put the screws back in. Once this is accomplished snap the speaker coverback on and that's it. It takes ten minutes once you get the speaker cover off.
Jun 08, 2009 | Bose Lifestyle 12 System
I WANT TO SUBSTITUTE 191 SPEAKERS FOR DOUBLE-CUBES WITH MY LIFESTYLE V20 SYSTEM
Yes, there should be no issues at all with just using different speakers. Just connect the 191's as you would the cubes and you should be fine. Please rate my answer, thanks.
Apr 28, 2009 | Bose Virtually Invisible 191 Main / Stereo...
Standard amplifier + Bose Lifestyle 12 Acoustimass module
well u didn't include any models # for the proton or "cubes" so all I can speak too is a simple heads up lesson about amp loading , most modern integrated amps look for a 4 ohm load for its speakers , this is saying total load , so if one was to connect say two speakers (plus to plus and minus to minus) assuming the speakers are 4 ohm already this would divide down to only 2 ohms (this would heat up the amp and affect it working ) but also if the speakers are say 8 ohms each then this divides down to 4 ohms (and the amp would see two as only one ) , also wire length between speakers counts as well , assuming most speaker rated size wire is say .023 ohms per foot this would also have to be added to the total load the amp see's , there are far more technical ways of running longer wires to other rooms but this involves impedance matching transformers and the like . so I'll not discuss them
May 26, 2017 | Bose Lifestyle 12 System
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
Nov 09, 2008 | Bose Lifestyle 12 System
Ok…
Tools:
large pliers
C-clamp
Instructions:
Aug 29, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
458 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
