Question about Emerson EWC1903 19 in. TV/VCR Combo
No sound,volume bar works
I have been all over the menu settings and tried everything with the remote,I still have no sound from anywhere(cd,vcr,tv)I have the back cover out and see no visible problems.Does anybody has the squematic diagram?Thank you
  • 1 more comment
  • Omar Urrutia
    Omar Urrutia Sep 01, 2006
    With volume up and the DVD playing I can barely hear sound information,I got a feeling something is wrong with the software but without a serv.Manual I dont know how to get into the service menu and check.I have checked the earphone,rca jacks,measured B+ to pin 10 of the outputs and it has the 12 volts.Thank you for the suggestions and information.Any more ideas?
  • Omar Urrutia
    Omar Urrutia Sep 06, 2006
    Hello techman,thanks to your information I have ordered the serv.manual on line,The unit is stereo and no sound from any of the speakers,when I touched one of the caps in that area I did get a buzz,same with the other output,I continuo to believe is in the wrong mode or something like that but I already have the manual so I have to do some measurements to find the problem,thank you for the suggestions,if you have any more keep them coming.
  • burns775 Jul 08, 2008
    there is absolutely no volume when playing only a dvd. the volume control works, the remote works, there is volume when playing a vhs or watching tv(our cable) but none whatsoever when watching a dvd. The dvd plays just fine, but it is completely mute, no matter what we attempt to do....?
    President:
  • 3,130 Answers
Sorry I dont have a manual but it is available at http://www.servicemanuals.net If you put your ear close to the speaker, with the volume turned up, do you hear any hiss or buzzing? If you dont it could be a bad speaker,headphone jack(if there is one), or the audio output IC or ascoiatated componets. If there is a hiss, then theres a problem with the audio processor or switching IC. If your not a tech, you should not be experimenenting around inside this TV set!
Posted on Sep 01, 2006
  • Larry  Dillon
    Larry Dillon Sep 06, 2006
    If you tryed another speaker jumped across the old one? if not try that first. If that does not work, see if there is any input on the audio output IC by touching a screw driver to ONLY the input pin of that IC with you touching the screwdriver with your finger. You should get a loud buzz. If you do not, the IC is most likly bad or a coupling capacitor is open.
SOURCE:
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
RCA Model 27F520T - it has no sound everything else is perfect?
I'm not sure what options are available in your audio menu, but here are some things to check before having a repairman check:
Click on menu screen, then select audio menu.
If there is choice of external or internal speakers, select internal.
If there is a noise cancelling option, deselect this.
If you are using remote to increase volume, try the manual volume button on tv.
Does the volume bar at the bottom of the tv increase as you adjust volume ?
Hope this helps
May 17, 2011 | RCA TruFlat 27F520T 27" TV
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
SONY KP 51WS500 - Volume & Menu won't stay on
This would be weird for a sony but it sounds like the volume down button on the front of the set is stuck...very very uncommon for a sony. Try taking the bottom front cover off the set and unpluging the button assyembly then see if the remote works the set with it unpluged.
Tim nolan
Sep 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
Nov 15, 2007 | Televison & Video
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Menu
THIS IS JUST A SUGGESTION .... PLEASE I HAVE A TOSHIBA AND I AM NOT AN EXPERT ON TV REMOTES!!! MY ORIGINAL REMOTE HAS A SWITCH ON THE TOP LEFT HAND SIDE OF THE REMOTE. IT HAS TV, CABLE,VCR, AND AUX. MAKE SURE YOURS IS ON "TV".(IF OURS ARE SIMULAR) IN THE MIDDLE OF MY REMOTE THERE IS A LARGE ROUND BUTTON WITH "ENTER" ON IT. PRESS THAT ONCE AND ALL THE MODES SHOULD APPEAR ON THE SCREEN. USING THE 4 ARROWS AROUND THE "ENTER" BUTTON YOU CAN CURSOR TO THE OPTIONS FROM MODE TO MODE. AND USE THE "ENTER" OR "EXIT" TO SET IT IN THE ADJUSTMENT YOU WANT. MY TOSHIBA IS A PIP "PICTURE IN PICTURE MODEL". MY CABLE REMOTE COMMANDER DOES NOTHING BUT WORK THE TV'S ON-OFF, CHANNEL, AND VOLUME. UNIVERSALS WILL NOT OPERATE THE REST OF TOSHIBAS OPTIONS ... THAT I HAVE FOUND ANYWAY. LIKE I SAID ... I HAVE A TOSHIBA AND HOPE YOUR TOSHIBA REMOTE IS SET UP THE SAME AS MINE OR SIMULAR TO HELP YOU OUT. I WISH YOU LUCK. JUST TRYING TO HELP.
May 02, 2007 | Toshiba MV20FM4 20 in. TV/VCR Combo
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
Aug 31, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Emerson EWC1903 19 in. TV/VCR Combo Logo
272 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
