Question about Brother HL 5140 Laser Printer
Drum Light is flashing yellow
Right after I changed the toner cartridge, the printer is working, but the Drum light is flashing yellow - what does this mean & how can I fix it?
  • 4 Answers
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Posted on Oct 28, 2008
I replaced the toner for the printer and the toner
No, remanufactured cartridges are just as good, and better for the environment if you get them from a reputable dealer. I buy all my toner cartridges from Qtoner.com and am very happy with them after trying a lot of other knock off non quality refurbished toner cartridges. You just have to find the right vendor.
With brothers, you have to manually tell the printer that you changed it. It tells you how in your owners manual. If you can't find it let me know and I can walk you through it to the best of my ability.
Hope this helps!
Jun 21, 2010 | Brother HL 5250DN Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Feb 16, 2009 | Oki Electric Industry C3300n Laser Printer
HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Jan 28, 2009 | HP LaserJet 1300 Printer
HP Laserjet 1300 yellow light flashing
Change the toner cartridge and see if the problem is rectified. Sounds like a part failure in the cartridge. This can happen at anytime, but more so when the cartridge is at the end of its useful life
Jan 23, 2009 | HP LaserJet 1300 Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Flashing red light
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
May 06, 2008 | Brother HL 1440 Laser Printer
Drum light flash Brother HL 2070N
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Feb 27, 2008 | Brother HL-2040 Laser Printer
Brother HL 5140 Laser Printer Logo
933 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
