Question about Samsung AS18A6RB Air Conditioner
Samsung MH026FPEA stopped after a few seconds with error code E154.
I don't know what E154 stands for.
Please can everybody help me what's the reason for and what should I do .
Thank's.
  • ernie_200 Dec 31, 2008
    same problem for model AS-12VBA
    error codes E1 and 54 keep flashing up
    If i turn the unit off for a while it seems to fix itself for a while
    the compressor in my as-24ba unit is shot and these units are less than a year old
    bummer as I live in Panama
    swishing I had bought LG
4 Suggested Answers
SOURCE: My Samsung electric dryer, model DV337AEG is
You have a bad heating element. I just went through the same problem with mine
Posted on Jul 26, 2009
  • 89 Answers
SOURCE: A error code E154 appears,
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Posted on Apr 26, 2011
Testimonial: "thanks I will do so"
SOURCE: i don't know the PUK
6467149769
Posted on Dec 21, 2011
SAMSUNG FREE STANDING GAS RANGE NX58F5500SS IT DONT STOP BEEPING AND IT SAYS "E-27" IVE ONLY HAD IT A MONTH ITS BRAND NEW. WHAT DOES IT MEAN?
Contact the vendor where you purchased the unit. It is still covered under warranty. If you give them the code, they will most likely know what is wrong.
Or search for:
Make Model error code E-27
Jul 16, 2017 | Samsung Kitchen Ranges
What does E154 mean? How do i fix it?
I dont know the brand or model, but if its a Samsung that error is for a faulty start up capactor, or fan. Caps need replacing after so many years. I have replaced so many I cant count.
Jan 28, 2015 | Heating & Cooling
Samsung code # DD68-00079A_EN
Dishwasher won't start. No error codes. Tried to see if it was locked. Held sanitize button for few seconds. Nothing happened. Please help. The panel is blank.
Jan 30, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Please help its cold
Try using Bing or Google and search for videos that show how to fix the problem. There are videos out there for everything, just keep searching.
May 15, 2013 | Heating & Cooling
I need to know how to setup my fax, didn't get a manuel with this machine. Thanks, Lynda
You can download the detailed User manual by a click on the following link.( http://olsonbros.com/samsung/specs/pdf/ib-sf755p.pdf ). May be it will take a few seconds to download.Please wait.Hope this helps.Please don't forget to rate me if satisfied.Thanks Linda for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Samsung SF-755P Laser Fax
A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
Apr 25, 2011 | Heating & Cooling
Only pumps water for a few seconds at start of cycle & then stops with 'LE' error code - have tried a few different cycle settings, but same error code comes up
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 22, 2010 | LG Washing Machines
Maytag washer won't finish cycle
If your machine a FAV6800A or FAV9800A please confirm the model nimber.
Is the machine erroring out with a dC or uC code to the display?
Let me know and we will go from there on a fix or a least how to keep the repair cost reasonable.
I would DIY the fix but I need your model number and the first two digits of your serial number.
Here is where the S/N is located on the machines for the forum you are in.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Samsung AS18A6RB Air Conditioner Logo
591 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
