Question about Samsung DV331AER Dryers
Samsung dryer dv331
Dryer lights turn on but motor won't start just clicks once
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
heatman101
  • 43501 Answers
SOURCE: lights come on but dryer will not start. I hear a
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
heatman101
  • 43501 Answers
SOURCE: we were turning our drum
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';
Posted on Jun 19, 2011
rickead1
  • 1998 Answers
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Posted on Jul 04, 2011
  • 2006 Answers
SOURCE: samsung dv218eb dryer runs but
No heat almost always means a heating element. But if you ar talking low heat, then check the lint filter; exhaust pipe for clogges and that the fan is circulating the heat up to the drum.
Posted on Aug 14, 2011
Samsung gas dryer dv331 will power up but won't run. The lights blink and the unit clicks one but won't start.
Try spinning the drum by hand. If it's really loose, then you need a new belt. I recommend getting this done by a professional, or you watch a youtube video. It takes a standard whirlpool belt.
Nov 03, 2013 | Samsung DV331AER Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 19, 2011 | Kenmore Dryers
My dryer turns on, but will not spin. I can turn it by hand, and it is clicking like it is trying to work, but it won't turn.
It could either be your motor capacitor which is the more common item, or the actual motor itself.
If you start the machine and can hear the motor running but no action, that is your drive belt. But if motor is struggling to turn it is your motor capacitor which basically kick starts the motor.
I am not familiar with the Samsung dryer as I have not seen them. Not sure if you are able to hold in the door switch with a screw driver and then start the machine. If so try this and turn the drum by hand. If this makes the dryer run after the initial jolt, then it is definitely your motor capacitor.
Sometimes the capacitor is inbuilt into the main control board.
Good luck.
Ash
Sep 02, 2011 | Samsung DV419AGW Dryer
Dryer lights up but won't start and none of the
heatman101
Aug 27, 2011 | Samsung Dryers
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
heatman101
Aug 09, 2011 | Hotpoint Dryers
Samsung DV331AER Dryers Logo
273 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
