Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony KP-53HS10 friend gave me this tv. plug it in, power it up. Excellent sound no picture at all, is there a possible fuse problem.
  • serapiosaria Dec 05, 2008
    I have the same problem, the standby/timer blinks 5 times. After powering on picture appear in a few seconds/great audio led light on Timer/ Standby blinks 5 times then pause then blink again.Sony KP-53HS10.
  • Sony Master
  • 586 Answers
HI,
No this is not a fuse problem, Audio is OK but video is not present.This shows that problem may occurred in various section like Horizontal section Video procession section But one thing is important that this is due to miner components like Resistance or Capacitor.So,you need not to much worry about it.Just contact any expert nearby.
Thanks
Posted on Oct 30, 2008
My sony kp-53hs10 light bllinks seven times, sound fine, no picture
Hello
Check its power supply regulator for failed component/s
Mar 04, 2012 | Sony KP-53HS10 TV
Picture has blue shadow/trail? sony KP-53HS10
This sounds like a bad blue CRT (cathode ray tube) The repair on this is a major job. Beyond the tube replacement it would then require some convergence alignment and possibly some setup on the other related service adj. such as geometry. You may want to get an estimate from a reputable local repair company.
Jan 25, 2010 | Sony KP-53HS10 TV
No picture
first of all sony uses blinks as a means of an error code, on older models like yours could be weak CRTs, try turning up the screen controls a little, if the picture comes on the CRts are weak and AKB is holding them dark. the controls are in the front behind the cover.
possibly you have no high voltage, D board or splitter is bad, bad convergence ICs will cause NP, check the 3.15amp fuses if any are blown replace ICs both stk392-110 and fuse to fix.
Jul 31, 2009 | Sony KP-53HS10 TV
KP-53HS10 blinking light
Ok I solved my own problem and posted the results here,
http://www.fixya.com/support/t1692655-sony_kp_53hs10
Mike
Dec 13, 2008 | Sony KP-53HS10 TV
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Sony kp-53s10
Power supply or scan failure is the usual cause. You will require service for this set.
Jerry G.
Apr 13, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS10
The problem seems to be in Secondary supply of Switching Power supply.
Mar 31, 2008 | Sony KP-53HS10 TV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
