Kyocera add paper cass - Office Equipment & Supplies
2 Suggested Answers
zsomboribala
  • 11 Answers
SOURCE: Kyocera FS3900DN reporting add paper
The problem is with paper pickup rollers.They are at the begining of the tras.
Try to clean it, and try to rotate it.
If it's not moving then try to disassamble it. You will see there is a spring underneath the rollers. Be sure if the spring stands in its place.
Feel free to ask.
Posted on Oct 11, 2011
How do I get past the error message: Add paper Cass.?
Hi
You need to check that the paper detection sensor just close to the rollers is still there , you might have blown it out of place or worse broke it ,
that's the only sensor that detects the paper
May 19, 2015 | Kyocera Mita Office Equipment & Supplies
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Ecosys fs-1350dn
Check the sensor flag that normally sees the paper when it lifts into position. If necessary, remove the toner cartridge before you have to turn the printer on its side. Take a good look for that sensor flag. It may either be stuck or, missing. Carefully move it and see if it's binding or rubbing against something. Good luck.
May 09, 2014 | Kyocera Office Equipment & Supplies
"add paper cassette"
Turn the printer off. Pull the paper cassette out and push down the green tab down to see if there is any paper jam inside. put the cassette back in and turn the printer on. Worked on my kyocera FS - 1370 DN.
Mar 16, 2012 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN reporting add paper cass
Feel free to ask.
Aug 18, 2011 | Kyocera FS-3900DN Laser Printer
What is sharp photocopier service center number because my sharp photocopier paper not pick up in normal tray
Hi don't know for the number, but...
If you want you can remove back cover of the cass. and see if the spring is broken, these is usually main cause for not lifting the paper in cass.
Dec 25, 2010 | Sharp AR-5316 Advanced Digital Imager...
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
94 people viewed this question
k24674
