Question about RTO Cycling
New coolster 110cc atv won't start
Brand new atv won't start. makes buzzing noise when attempting to start. battery charged. son and dad upset.
5 Suggested Answers
  • 5 Answers
SOURCE: my atv air cool keeps runnig hot
You might need to get the air filter cleand or changed, as well as the rest of the air intake system altogether.
Posted on Dec 07, 2009
  • 4 Answers
SOURCE: I need to replace the clutch in my sons tao tao
You'll need a Clutch Hub Nut like this one:
http://www.compacc.com/p.cfm/c/1111010/p/18219
You'll also need to hook it up to an Impact Driver like this one:
http://www.amazon.com/Bare-Tool-DC825B-18-Volt-Cordless-Battery/dp/B002RT7K4Q/ref=sr_1_6?ie=UTF8&s=hi&qid=1260243742&sr=1-6
Remove the engine cover (on the right). If you damage the gasket (most likely), you'll need to replace it when reassembling. Unscrew clutch top (4 screws). Use a flat screw driver to release washer lock (it holds clutch nut locked. Only one of several locks would be engaged). Use impact driver to unscrew clutch nut. Remove nut and 2 washers. Remove clutch. Reverse process to install new clutch.
Visit emotorbike.com for more info. Or call 856-782-9189.
Posted on Dec 08, 2009
  • 4 Answers
SOURCE: I cant get my 110cc atv to fire
1. See if you can get a spark.
2. See if fuel does reach carburetor.
3. Is your magneto still good?
4. Is your starter trying to crank up engine?
5. Is your CDI box sound?
So many questions that need to be narrowed down. What have you tried?
  • 6 Answers
SOURCE: how to set timing on a china 110cc atv
whats the point? Go buy and American Made bike then I'll tell ya
Posted on Aug 21, 2010
We have a 125 coolster. And it makes a clicking noise.
Hi, Tammy could be a starter solenoid or valve tappet noise I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have nice a day. Coolster Mountopz Atv 3125b 125cc Chinese Atv Owners Manual Om atv3125b...
50cc 125cc Chinese Atv Repair Manual Set Om 110set Service and Repair...
http://canadattatv.com/wp-content/media/book/110cc%20&%20125cc%20Service%20Manual.pdf
http://www.scootermasters.com/manuals/125_service_manual.pdf
May 12, 2016 | Motorcycles
What could cause atv 110 engine to not turn over at all? Battery is good, seems as if kill switch is engaged.
check for a fuse that's going to be close to the starter solenoid. next take a piece of metal like an old screw driver and jump the 2 posts on the solenoid to see if it cranks. if nothing happens your either going to have a bad connection or a bad starter. if it does crank then I would look at your start switch or ignition switch. just start chasing wires and making sure there all good, theres nothing fun abut chasing electrical problems so take your time and crack a beer.
Aug 07, 2014 | Roketa 110cc Middle Size ATVs
Kawasaki problems
it can be a few things it can be a bad solonid, bad connection, bad battery, or your starter needs new brushes
Jul 23, 2014 | kawasaki 2010 Mule 600
I have an atv that won't start.
Could be your starter, solenoid, or even a fuel pump/clogged lines or filters
Jun 04, 2013 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Chinese 110cc atv won't start fuel good no signal to coil
there is a little black box with 6 wires 5 of them used on the left side of the frame in the front try that but if the plug in the back is un hooked or not working follow the wire from the bail cord socket and unplug it and put a wire between the two prongs that would eliminate that issue from the bail cord switch hope this works for you
Nov 13, 2012 | RTO 110cc Basic Manual ATV # ATD-125C
Ares 110cc four wheeler won't start gas not getting to carb
chk your tank and lines for trash blockage, when you get fuel to the carb go from there, the overflowing is caused by the needle valve in the carb sticking open, usually caused by trash in the fuel, make sure you are getting fire to the plug as well, I know for a fact the wiring systems on these things are not quality systems.
Oct 25, 2012 | RTO 110cc Basic Manual ATV # ATD-125C
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
Cycling Logo
126 people viewed this question
Top RTO Cycling Experts
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
