Question about Saws
How do you re-install the Skillsaw 5150 blade?
We removed the old blade (unfortunately we didn't pay close attention to how the old blade was in there to begin with), but when we re-installed the new blade there was no power when turned on. At first we thought the saw, since it is very old, just died; however, when we removed the blade and tested it the motor still ran fine.
Is there some sort of lock we are missing when we re-installed the blade? We tried, at least what we think was, every variation on the position of the washers (I guess that is what they are) around the blade and still no power.
I'm sure it is something very simple, but we need HELP!!
    Problem Solver:
  • 15 Answers
I,ve personally never heard of a problem quite like yours. I use skill saw brand saws every day and the arbor and washer will only make the blade wobble if installed incorrectly. Blades can be turned around to cut different types of material as well. Check to make sure the hole or diamond is the same on the new blade(you might have to punch it out) if its not seeding properly on the saw, you could also check under the guard to make sure nothing is binding the saw. The only other thing I could suggest would be to check the lock button (the one you hold to change blades, that stops the saw motor from turning) if that is stuck, your saw won't run. Good Luck!!
Posted on Nov 18, 2008
Why is my skillsaw 5150 running in reverse?
Make sure the blade is mounted so that the teeth are cutting UP through the workpiece.
Jun 27, 2015 | Computers & Internet
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
How do i replace the blade on my utility knife?
loosen the screw that is holding the two casing halves together and separate the halves. pay attention to which way the old blade is in the compartment, remove it and put in a new blade in the same direction. close the casing and tighten the screw
Jan 16, 2013 | Cutter Tools
How to change the belt
First, lay the saw on it's side with the blade facing up.
you should see an access panel at the base of the blade. Remove the screws and the panel. This should reveal two hat nuts and the chain drive sprocket. Loosen the two hat nuts, allowing you to slide the chain bar backwards and remove the old chain. Loop the new chain around the bar and drive sprocket, paying special attention to the direction of rotation of the chain. the cutting surface of the teeth should face the handle of the saw on the BOTTOM side of the blade. Pull forward on the bar and HAND-TIGHTEN the hat nuts. This will allow you to adjust the blade tension. Pull outward on the chain at the cnter of the bar. Slide the back and forth until you acheive about 1/4 inch gap between the chain and the bar. Once you are satisfied with the tension, tighten the hat nuts with a wrench and replace the cover and screws. Just pay close attention to the tension of the chain. Too loose and it will skip off, too tight and will bog down the motor and overheat.
Apr 29, 2011 | Garden
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
It stopped running while vacuming and would not start again
The most likely problem is the cord end is broken, it is cheap to replace if you do it yourself. if it is a plorized plug ( one blade is bigger than the
other ) pay close attention what side the wires go to and match them on the new one.
Nov 16, 2009 | Vacuums
How do I replace a skilsaw blade?
The saw has a bolt in the center of the blade. The saw blade will have to be held in place, (so it can't turn), while the bolt is being loosened. Pay attention to the rotation direction, as your replacement will need to rotate in the same direction. Once you have removed the bolt, there is a centering spacer that fits between the bolt and the blade, remove it paying attention to how it fits..you will need to put it on the new blade in the same manner. You can now remove your blade and replace. Good Luck. I hope this is very helpful!
Nov 14, 2009 | Craftsman Saws
How to repair stabilizer bar or sway bar
Keep a large prybar nearby, install the new links paying VERY close attention to the arrangement, Lower the sway bar with the prybar until you can get the locking fastener a few threads on and repeat for other side. P.S. to remove the old links a sawzall is VERY handy.
Jun 23, 2009 | 1999 Jeep Wrangler
Remove me Steering wheel bmw 1999 e46 3 series
Disconnect negative battery cable. Locate airbag retentions on back of steering wheel. Unbolt or unclip retention devices, and release airbag. Then: Unplug airbag electrical connector. Remove nut or bolt in center of steering wheel with pneumatic impact wrench if necessary . Using appropriate steering wheel removal tool kit, carefully remove steering wheel, paying attention to associated wires, etc. Unplug anything not accompanying wheel, or that is in the way. Pay close attention to any rods, or contact pieces associated with the horn button(s.) Replace these upon reinstall. Reverse order to install including tightening center bolt to 35-55 ft-lbs. If this is your first stg wheel removal, try an old chevy, preferrably someone else's! If inexperienced, don't risk bruising your favorite Bimmer!!! Hope this helps you make your decision. Tater Todd
Jan 28, 2009 | 1999 BMW 318 ti
Saws Logo
1,748 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
