Question about Lenovo Computers & Internet
4-4-1-2 beep code
Just beeps without even reaching post. Tried new memory, cpu and hd. Probably bios crushed??
gilheero
  • 207 Answers
SOURCE: re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Posted on Jan 16, 2008
  • 86 Answers
SOURCE: Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Posted on Jan 27, 2008
rajkar
  • 21 Answers
SOURCE: about the beeps
here is a post on beep
http://www.computerhope.com/beep.htm
Posted on May 11, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
  • 341 Answers
SOURCE: P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Posted on Dec 10, 2008
Dell Inspiron 1012. On power on I get 7 long beeps recuring about every ten seconds or so,the screen remains black and no hdd activity I have checked the hdd and all ok,memory seems ok beeps still sound...
The beeps during startup depend on the BIOS. Here are some possible causes of the seven slow beeps on different bios:
AMI (American Megatrends') = virtual mode exception error.AST Research = Processor register read/write verify test failed. Compaq = AGP video.Mylex = DMA page registrater error.
there are others which i didn't include....
Jul 27, 2011 | Computers & Internet
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
Beeps beeps beeps everwhere on my desktop
Depends on the BIOS. The beep code means ether the memory or CPU. Since you are attempting to install a another CPU its probably a problem with the CPU itself (dameged or incompatible) or a BIOS setting problem. Also make sure you always use thermal paste. The replacement CPU might be heating up and not functioning.
May 26, 2009 | Asrock K7S8XE Motherboard
The motherboard makes a 3 second beep over and over.
Nick,
That beep code usually signifies one of the devices connected to your motherboard is having an issue and the motherboard is not able to past the POST.
You will have to do some digging to determine the cause of the problem. First step, remove the RAM, and see if the error code changes.
How did the bracket brake? If it is broken your CPU or CPU Socket might have gone bad.
If you're thinking about upgrading, you might as well ditch the PC2700-3200 and upgrade to DDR2 or DDR3. PC2700 is DDR which is becoming a phased out product line. Just FYI.
Hope this helps.
As a reminder, if this post helps, please rate it. Thankyou.
Feb 27, 2009 | ASUS P4S533-X Motherboard
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
3 long beeps 3270 keyboard card
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Computers & Internet Logo
109 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
