Question about Akai LCT2715 27 in. LCD Television
RE: Akai LCT2715
I believe my power supply went, you re-build them?
How does one go about getting you the bad unit out for repair/rebuild?
Thanks
John Zarra
jzarra@yahoo.com
    Champion:
  • 367 Answers
What is the make,and model of it?Do you have the back off of the TV?If so,look at the can shaped items on the boards.Do any of them have the tops,or bottoms bulged out?If so,they need to be replaced.This should get it working again.Do you know how to solder?I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Nov 02, 2008
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct2715 power supply repair needed. Please respond. Failure appears to have occured over several days. First picture had distortion at edges. Then blue AKAI screen would light but picture was not in...
I very highly doubt that is merely a power supply problem,I would suspect that it is a small signal board (aka scaler board) or at the very least,have the inverter boards checked
Jul 16, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct2701ad will not power up
The power supply is defective if the TV fails to power up or the front light just blinks, common failure on these LCDs with MLT166A power supplies.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Mar 05, 2009 | Akai LCT2715 27 in. LCD Television
Accessing user mode on my AKAI LCT 2715
On my Akai LCT2715---- Ok, I had the same problem with locating USER MODE (even called Akai service HELP and that person didn't know anything)!!! even tho we looked through manual just got TV back from putting $184 in Capacitors repair (PUT IN NEW NICHICON CAPACITORS) from the standby button not woking just flashing from the Power Supply gone bad plus 2 main capacitors other than power supply that were bad. Works great now. For the USER MODE look on the remote in the bottom black area repeatedly push the P.MODE. You should have full function to adjust all in menu list WE DID.
Jan 24, 2009 | Akai LCT2715 27 in. LCD Television
Need Power Supply for AKAI LCT2715 Repaired
I repair these power supplies.
If you require further assistance you can write to jah2mil@hotmail.com
Dec 27, 2008 | Akai LCT2715 27 in. LCD Television
Power supply rebuild
You can write to jah2mil@hotmail.com for more info on repairing cost and where to send the power supply for repair.
Dec 24, 2008 | Akai LCT2715 27 in. LCD Television
27 akai lct2715 POWER SUPPLY
Have you had your power supply repaired? If not i can possibly help you with this issue.
Nov 07, 2008 | Akai LCT2715 27 in. LCD Television
RE: Akai LCT2715
You would have to remove the Power supply if you feel comfortable doing so or you could send the whole TV but that could cost a bit....
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
LCT2715 Power Supply
Contact info sent, I will await your reply.
Oct 21, 2008 | Akai LCT2715 27 in. LCD Television
probly bad capacitors on power supply this unit is prone to this, just fixed on for ten dollars. there are many post on repair of this unit.
Aug 20, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
41 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
