Question about Adobe Photoshop 7.0 for PC
Scratch & windows error
I'm trying to install photoshop 7 on windowsXP.
Installation complete and when i open photoshop i get the following error message:
"You currently have adobe photoshop's primary scratch & windows primary paging file on the same volume, which can result in reduce performance. It is recomended that you set photoshop's primary scratch volume to be on a different volume preferly on a different physical drive".
After cliking OK, application continues to upload, then generates an error Alert...of a hardware problems and closes down.
Is anybody familiar with this problem? i used this photoshop version before on other PCs and had no issues..
Please help.
Thank you
I can't even get to the Edit menu in the photoshop menu to change the scratch..
..i dont even get to the point where i can click there as it closes down when the application starts to upload.. this is the 2nderror i get from photoshop...after the Primary Scratch warning..
i cant even get to the menu of photoshop. i must click quit and the application closes down
Any idea?
  • 73 Answers
You must change the location of Photoshop's primary scratch disk to a different HD or other HD partition. You can do this using the Windows Explorer
Posted on Nov 05, 2008
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
Photoshop 7 using windows 7
using the program photoshop cs 7 in Windows 7 is easy, you just install and follow the instructions until the installation process selesai.dan photoshop software you are ready to use.
Jul 22, 2011 | Adobe Photoshop 7.0 for PC
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
I have a problem with my netbook which can't start, I have this message: ...the following file is missing or corrupt: windowssystem32configsystem
Hi
Windows system 32 config file is part of the operating system and when this is missing or corrupted, you cannot boot up your computer. The only solution is to reinstall or repair your operating system. Good Luck.
Jan 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
Please help me my SN:
3. Open Keygen and Generate a Serial Number. Highlight the Serial Number and hit CONTROL + C to copy it to the clipboard. LEAVE THE KEYGEN OPEN. DO NOT CLOSE THIS KEYGEN.
4. Next, start the installation of PhotoShop CS2 V9.0
5. When PhotoShop CS2 starts installing, a window will eventually appear asking for a SERIAL NUMBER. Use the CONTROL + V key to paste the SERIAL NUMBER in the appropriate space.
6. Follow the installation wizard of PhotoShop until installation is complete.
7. After installation is complete, a window will appear to activate Photoshop. Click ACTIVATE BY TELEPHONE Button and then click ACTIVATION INFORMATION BUTTON. A new window will appear.
8. In this new window you will find an activation number. Highlight ACTIVATION NUMBER and hit CONTROL + C keys to copy to clip board.
9. Go back to KEYGEN and in the ACTIVATION NUMBER FIELD, hit CONTROL
+ V to copy activation number to KEYGEN.
10. After ACTIVATION NUMBER is copied to keygen, click GENERATE AUTHORIZATION CODE on KEYGEN.
11. MAKE Note of ACTIVATION CODE of KEYGEN. Return to Photoshop and manually type ACTIVATION CODE to PHOTOSHOP ACTIVATION WINDOW. Follow instructions after activating product.
Nov 25, 2010 | Adobe Computers & Internet
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
Installed photoshop 7 on my laptop and everytime I start the program and click on editor, it tells me the program will automatically shut down. Is there a fix for this problem?
The error telling you that Photoshop 'will automatically shut down' is a waterd-down way of telling you there was a critical error and that it was not able to open. There appears to be a corruption in your Photoshop installation.
I would recomend uninstalling Photoshop 7 and then re-installing it again as follows:
- Click Start > Control Panel > Add/Remove Programs (or 'Programs' in Vista or Win7)
- Locate Adobe Photoshop 7 and click on it and select Uninstall.
- When it has completed, restart your PC.
- Once restarted, re-install Photoshop 7 via the CD/DVD.
Hope this helps,
-Tor
Nov 21, 2009 | HP Computers & Internet
Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Oct 28, 2008 | Adobe Photoshop 7.0 for PC
No sound device after complete installation of all drivers.
Hi there.
I had to install WindowsXP from scratch, due to a virus infection. After complete installation of the WindowsXP, I installed all the drivers from the disc that was included with the motherboard. Yet for some reason, when I open windows media player, there is no sound device. What seems to be the problem?
Can anyone of you help me withit?
Sep 28, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Adobe Photoshop 7.0 for PC Logo
157 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
