Question about HP LaserJet 3015 All-In-One Printer
Check paper tray check cartidge.
I keep getting a message and the light (orange is blinking) to check paper tray check cartidge. we have checked the paper tray, changed the toner which did not need to be changed tried to find any paper jam with no sucess. what do we need to do now
  • ladd47 Nov 19, 2008
    my printer will not print or copy reads clear carrier jam and poor alignment what does this mean and how do i solve this problem
  • brucelee2009 Jan 06, 2009
    check cartridge check paper tray. replaced catridge, replace new stack of paper, reboot HP device. no success
    Scholar:
  • 195 Answers
I have the 1350 all in one, and when I changed my cartridges I screwed up and replaced both at the same time, that was a no no as I found out. I kept getting the test printer and print example too. so what I had to do was Uninstall the printer and drivers, then reinstall them again, that worked.
Posted on Oct 28, 2008
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Check print cartidge light keep blinking and the light on copies showing empty while there is paper in the tray
Issue: The Check Paper and Check Print Cartridge lights blinkIn this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : On
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : On
  • Color Start Copy light : On
Figure 79: The Check Paper and Check Print Cartridge lights are blinkingc00864299.gif
    hpweb_1-2_minus.gifCauseThe carriage is stalled or jammed. A message indicating that the carriage is stalled might appear on the computer.You might also experience the following symptoms:
    • The product will not print.
    • The carriage is stuck and does not move.
    • The product makes loud grinding noises.
hpweb_1-2_minus.gifSolutionsSolution one: Turn the All-in-One off and then on againFollow these steps to turn the product off and then on again.
  1. Press the On/Resume button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the On/Resume button (c01602202.gif ) to turn on the product.
  4. Check the lights on the control panel to make sure that they are no longer blinking.
  5. Try the intended task again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Make sure that the front panel overlay is installed correctlyIf the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay.If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
Oct 07, 2011 | HP PSC 1210 All-In-One InkJet Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
HH
Aug 12, 2009 | HP LaserJet 5p Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
Dec 24, 2008 | HP LaserJet 1300 Printer
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
HP LaserJet 3015 All-In-One Printer Logo
175 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
